Learn how to train a model with AI Training to classify sounds.
This is the next step after you have designed the model with AI Notebooks. You can see the Notebook step in the tutorial: Audio analysis and classification with AI.
It's strongly recommended to read the Notebook tutorial before reading this tutorial.
ย
- A Public Cloud project created
- The ovhai CLI interface installed on your system (more information here)
- Docker installed and configured to build images.
- An OCI / Docker image registry. You can use a public registry (such as Docker Hub for example) or a private registry. Refer to the Creating a private registry documentation to create a private registry based on Harbor.
- Knowledge about building images with Dockerfile
ย
Create object storage for data
To train the model you'll need data and a place where to save the trained model. You can reuse the previous object storage used in the Notebook tutorial Audio analysis and classification with AI or follow the step Uploading your dataset on Public Cloud Storage of this same tutorial.
ย
Train your model
To train the model, we will use AI Training. This powerful tool will allow you to automate your pipelines and build fine-tuning phases easily.
AI Training allows you to train models directly from your own Docker images.
First, you need to create a Python script that is in charge of doing the training. You can copy and paste the following code in a file named train-audio-classification.py:
The tensorboard step is not mandatory. It's just a way to monitor your training.
Then, create a requirements.txt file to declare the Python dependencies:
tensorflow numpy==1.22.4 pandas scikit-learn keras
Then, create a Dockerfile compliant with AI Training. You can copy and paste the following code in a file named Dockerfile:
Then, build the Docker image and push it in the registry:
The output should be similar to this:
Once your Docker image is created and pushed into the registry, you can directly use the ovhai command to create your model training. You can launch the training specifying more or less GPU depending on the speed you want for your training.
If your images are stored in a private registry, please follow the documentation Registries - Use & manage your registries to add your registry.
You can access to the execution logs of your job with the CLI:
For more explanations about the CLI command for AI Training, please read this guide: CLI Reference.
Once you have your model ready, deploy the model to use it. This will be done with the AI Deploy tool.
ย
All the source code is available on the OVHcloud GitHub organization.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
