Learn how to train your first Model in AI Training.
At the end of this tutorial, you will have learned to master OVHcloud AI Training.
We will show you how you can:
- Upload your data to the OVHcloud Object Storage.
- Launch your training job and attach your data to its environment so your model can access your data.
- Monitor the progress of your job.
- Download your model in the cloud to retrieve it once trained.
Each step will be accompanied by an example to guide you.
What is AI Training?
AI Training allows you to train your models easily with just a few clicks or commands. This solution runs your training job on your chosen computational cloud resources (CPU/GPU). As soon as your training job is finished, the status of the AI Training job will change from Run to Done, which means that the billing will be stopped immediately. Thus, you will save time and increase your team's productivity while respecting the integrity of your sensitive data (GDPR).
AI Training is compatible with leading applications and frameworks like Pytorch, Scikit-learn, TensorFlow, Transformers, and others!
More information about AI Training can be found here.
Use case
We will train an image classifier on the Fashion MNIST dataset. This dataset contains 70,000 examples of Zalando's article images. Each one is a 28x28 grayscale image associated with a label from 10 classes. This dataset is available on their GitHub repository, but you can directly download it from Kaggle. It is a .zip file (72MB).
- An AI Training project created inside a Public Cloud project in your OVHcloud account
- A user for AI Training
- A Python script that trains a model
NOTE: For more in-depth instructions, see our GitHub page on this process.
You will follow different steps to export your data, train your model, and save it.
Step 1 - Upload your data to the OVHcloud Object Storage (optional)
This step is optional because you may load some open datasets through libraries, commands, etc., so you will not need to upload your own data to the cloud.
On the other hand, you can upload your data (dataset, python and requirements files, etc.) to the cloud, in the Object Storage. This can be done in two ways: either from the OVHcloud Control Panel or via the ovhai CLI.
This data can be deleted at any time.
1.1 - Upload your data via UI (Control Panel)
If you do not feel comfortable with commands, this method will be more intuitive for you.
First, go to the OVHcloud Public Cloud section.
Then, select the Object Storage section (in the Storage category) and create a new object container by clicking Storage > Object Storage > Create an object container.
NOTE: At this time, you must use Swift Object Storage if using the OVHcloud Control Panel to create your object container.
Here, you can create the object container that will store your data. Several types and regions are available; choose the best parameters for you.
Once your object container is created, you will see it in the Object Storage list. Click the one you just created. Here, you will be able to click the Add Objects button, which will allow you to store your data in the cloud.
WARNING: When you upload your data, do not add a prefix to the file. Folders in your Object Storage container do not correspond to the mount directory needed for your AI workspace.
Using the manager to upload your data can be very long. We recommend using the OVHcloud AI CLI.
In the OVHcloud Control Panel, you can upload files but not folders. For instance, you can upload a .zip file to optimize the bandwidth and then unzip it in your code. But if your dataset is already split into several folders, you must use the AI CLI to upload them.
1.2 - Upload your data via CLI
To follow this part, make sure you have installed the ovhai CLI on your computer or an instance.
As in the Control Panel, you will have to specify the region, the name of your container, and the path where your data will be located. The creation of your object container can be done by the following command:
For example:
Assuming a file named my-dataset.zip exists in your current working directory, you can use the following command to create an object container named fashion_MNIST_dataset, located in the US-EAST-VA region that will contain your my-dataset.zip file.
This .zip file can now be accessed from all OVHcloud AI products, either with read-only (RO) or read-write (RW) permissions.
Step 2 - Launch your training job and attach your data to its environment
To launch your training job, you can also use the OVHcloud Control Panel or the ovhai CLI.
2.1 - Launch a training job via UI (Control Panel)
Now, select the AI Training section (in the AI & Machine Learning category) and create your job by clicking Launch a new job.
Here you will have to specify a region and a Docker image. Depending on the framework you are using in your project, you will have to select the Docker image that suits you best. This will reduce the number of library installations you need to do. You can either choose one of our proposed images or use your own! To discover how to build your own image, please read this documentation. To push this image into a registry and use it with AI Training, follow the use & manage your registries documentation.
In both cases, make sure to mention in a requirements.txt file all the libraries that are not included in the selected image. For example, the Pytorch image does not contain the Pandas library. Since our code uses it, we will have to mention it in our requirements.txt file and install it, or the job will not run correctly.
Then, you can toggle the I want to link volumes of data to the job switch, to attach your Object Storage container(s) to your job environment and access the data you have stored in the cloud (dataset, python files, requirements.txt, etc.).
If you have not created an Object Storage, don't worry; this step is optional.
If you want to add yours, just select the container that contains your data and specify the mount directory you have mentioned in your Python code.
For example, we load our data by calling the /workspace/my_data/my-dataset.zip folder in our Python code. This is why we choose /workspace/my_data as the mount directory.
Depending on your needs, you can enable or disable the cache and select the permission you want. Since we want to both read our data and be able to extract the zip file (which means write new files) and save our model once it is dragged into this object container, we will opt for the Read & Write permission on this container.
A good practice is to attach a container with your input data and attach a second container to save the output data in.
But since we want to keep this tutorial fairly simple, we will use only one container for our data.
Then, in the Enter the Docker command step, you can specify the command that allows you to install your libraries and run your Python script, which are both contained in your object container.
- Example:
Assuming you have added your train-first-model.py file and your requirements.txt file to a container that you have linked to your job with /workspace/my_data as your mount directory, you can then use:
This feature is currently being updated. You may encounter problems when using it. If this is the case, we advise you to use the AI CLI.
To finish, you just have to enter an SSH command in case you would like to access the job remotely via SSH, and you must specify the resources of your job (number of CPUs or GPUs). When everything is done, you can launch the job by clicking the Create button.
2.2 - Launch a training job via CLI
If you prefer to launch your job with the CLI, the principle is identical to the UI method. Indeed, you will have to attach your data volumes to a mount directory, specify your resources (number of CPUs or GPUs) and your region, for the same reasons explained above.
A classic training job can be launched with the following command:
Arguments
<docker_image_name>: Choose the Docker image you want to use to create your environment. You can get a list of the framework images hosted by OVHcloud here. You can also use your own Docker image.
<nb_gpus>: Number of GPUs your job will be run on. You can also use CPUs by replacing this line by --cpu <nb_cpus>.
--volume: Volume you want to add to your job (object container or public GitHub repository).
You can add several volumes to your job by calling the --volume argument several times. You can also add a GitHub repository as a volume.
-- bash -c: Allows you to provide commands through which you can, for example, install the libraries mentioned in your requirements.txt file, and run a Python script.
If you have followed the optional part that shows you how to store your data (first step), you can load your volume with the --volume parameter. You will have to specify the object_storage_name, its region and its mount_directory.
Depending on your needs, you can select the permission_mode you want (Read-Only with RO, Read & Write with RW, and Read, Write & Delete with RWD). To finish, you can also enable or disable the cache on your volume by adding :cache just after the permission_mode.
Otherwise, you can remove the --volume line since it will not bring anything to your app.
To give you a real example, here is the command we will use to launch our job, assuming this time that our my-dataset.zip is contained in a fashion_MNIST_dataset container, with a mount_directory named /workspace/my_data, and that our Python file and our requirements.txt file are in the ovh/ai-training-examples GitHub repository:
Whatever method you use, make sure to specify one mount path per volume. They must be different in order not to conflict.
Step 3 - Monitor the progress of your job
When your job is launched, you can follow its progress (loading of your volumes, evolution of the job status, follow your prints, etc.)
Monitor via UI
This can be done by clicking on your job's name, in the AI & Machine Learning > AI Training. You will find there two categories:
Job Information: There you will find the general progress of your job. -
Logs: This is particularly useful for tracking your prints and to understand why your job could not be launched, in the case of errors. You will find a console that will display all this information.
Monitor via CLI
Once your job is launched, you will get a lot of information via the CLI. Two main ones will be useful: the Id of your AI Training job, given in the very first lines (not to be confused with the ID of the added volumes), and the Info URL.
The Info URL will allow you to visually follow your job live. You will see the progress of the loading of your volumes, the status of your job which is evolving and will go to Running at the time of launch.
Warning: When the job is running, the auto-refresh option of the Info URL page is automatically disabled. Remember to reactivate it if you want to see when your job will be finished and will switch to Done status.
As mentioned before, logs are useful to follow and understand the progress of your job. To take a look at it, use the following command:
If you are not present when the job is finished and goes to Done, don't worry, the billing stops automatically!
Step 4 - Download the trained model
We can now download the trained model, again in two ways (UI/CLI).
Download via UI
Just click your object container as if you want to add new files to it. This will allow you to see all the files that are contained in it. You should find your trained model in it, that you can download by clicking the more options ... button.
Download via CLI
If you prefer to use the AI CLI, you will need to use the following command:
Arguments
<BUCKET>: container@data_store. Name and region of the container to download from.
[OBJECTS]...: Name(s) of object(s) to download.
For more info about this command, you can use:
For example, in our case we will use:
- If you want to learn about Docker, check out this tutorial.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
