Definition
- Data relates to any type of file (binary, text, code, images, etc.) that you want to use inside with OVHcloud AI tools.
- Object Storage is a scalable, resilient, and secure storage place accessible from anywhere through HTTPS APIs. It is a perfect place to store static files for the long term.
- Volumes are filesystem storage units mounted and used inside AI Training jobs and AI notebooks.
Best practices
OVHcloud Object Storage should be used to persist any data needed by AI Training jobs or AI notebooks.
There are two ways to manage your data:
- You can upload and download data from your local environment using the CLI (see how to install ovhai CLI). Next, find out how to manage your data with the CLI.
- You can use the OVHcloud Control Panel; see create data container.
How it works
AI Training jobs and AI Notebooks can read and write data from and to the OVHcloud Object Storage. Here is what is happening under the hood.
AI Training
- Before the job starts, data is synchronized from the object storage into an underlying filesystem volume. This synchronization is done during the
INITIALIZING
phase. - When the job starts, the volume is attached to the desired directory. Data is then available inside the job as long as the
RUNNING
phase lasts. - After the job stops, data is synchronized back from the underlying filesystem volume into the OVHcloud Object Storage. This synchronization is done during the
FINALIZING
phase.
AI Notebooks
- Before the notebook starts, data is synchronized from the object storage into an underlying filesystem volume. This synchronization is done during the
STARTING
phase. - When the notebook starts, the volume is attached to the wanted directory. Data is then available inside the job as long as the
RUNNING
phase lasts. - After the notebook stops, data is synchronized back from the underlying filesystem volume into the OVHcloud Object Storage. This synchronization is done during the
STOPPING
phase.
Capabilities
Access rights
Users can give three different access rights on Filesystem volumes attached to jobs and notebooks:
Read Only (RO
): You are only able to read data in your job or notebook. It is forbidden to write, modify, or delete data in this container.
When to attach a volume in read-only RO
The purpose of read-only permissions is to ensure that you do not modify your data by mistake. This permission is recommended for your input data: images, videos, sounds, text, CSV files, etc.
NOTE: Volumes that are in read-only mode are not synchronized with the Object Storage during the FINALIZING
or STOPPING
phase because there is no point in synchronizing data that has not changed during the life of a job or notebook.
If you have directly added data from the Object Storage to the container connected in RO
, you can request an intermediate synchronization. Otherwise, your data will be synchronized at the start of your next job or notebook.
Read Write (RW
): You have full access to your data in your job or notebook. You can write, modify, or add data in this container.
When to attach a volume in read-write RW
The purpose of the read-write permission is to modify the contents of the object container. This permission is recommended if your container contains code (e.g., a Python file), a notebook, or if you want to save a model or connection weights after your training.
Volumes that are in read-write do not allow you to delete data from your Object Storage. If you delete data from a job or notebook, it will still be present in your object container, even after synchronization.
Read Write Delete (RWD
): You have full access to your data in your job or notebook. You can write, modify, add, or delete data in this container.
When to attach a volume in read-write-delete RWD
The purpose of the read-write-delete permission is to be able to modify or delete the object container contents. You can not only make changes to the different files in your container (Python code, requirements file, etc.) but also, especially, delete data from it. The RWD will allow you to permanently delete data you no longer need from your object container. This permission can be used if you want to delete old codes or connection weights, which can be heavy files.
NOTE: After the synchronization phase, your data deleted from your notebook or job will be permanently deleted in the Object Storage.
For a volume in RW
or RWD
: As long as your job or notebook is in the FINALIZING
or STOPPING
state, this means that the upload is still in progress. Once the state changes to INTERRUPTED
or STOPPED
, it means all the data was uploaded to your Object Storage.
Volume caching and sharing
By default, filesystem volumes are created and deleted on the fly for each job as needed.
Users can enable a cache
feature that allows jobs and notebooks to re-use available volumes instead of creating a new one each time. That feature serves two purposes:
- Reducing synchronization time for data that has already been downloaded before.
- Sharing the same volumes between several jobs or notebooks.
NOTE: Unused volume data is regularly deleted. Users should not rely on this cache
feature for long-time persistence.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
