Over the past few years, the field of computer vision has experienced significant growth. It encompasses a wide range of methods for acquiring, processing, analyzing, and understanding digital images.
Among these methods, one is called image segmentation.
The purpose of this tutorial is to show you how it is possible to build and train a brain tumor segmentation model with OVHcloud AI Notebooks. You will be able to learn the concepts of medical imaging, image segmentation, model evaluation, and much more. We will use a popular convolutional neural network named U-Net.
At the end of this tutorial, you will have learned the principal methods to segment brain tumors.
- An AI Notebooks project created inside a Public Cloud project in your OVHcloud account
- A user for AI Notebooks
- A Kaggle account to download the dataset
You can launch the notebook from the OVHcloud Control Panel or via the ovhai CLI.
A direct link to the full code can be found here.
Launching a Jupyter notebook with "Tensorflow" via UI (Control Panel)
To launch your notebook from the OVHcloud Control Panel, refer to the following steps.
Code editor
Choose the Jupyterlab code editor.
Framework
In this tutorial, the tensorflow framework is used. If you use another environment, there may be some compatibility problems such as missing libraries.
Resources
Using GPUs is recommended because medical imaging is a training-intensive task.
1 GPU is sufficient.
Launching a Jupyter notebook with "Tensorflow" via CLI
If you do not use our CLI yet, follow this guide to install it.
If you want to launch your notebook with the OVHcloud AI CLI, choose the jupyterlab editor and the tensorflow framework.
To access the different versions of tensorflow available, run the following command:
If you do not specify a version, your notebook starts with the default version of tensorflow.
You will also need to choose the number of CPUs/GPUs (<nb-cpus> or <nb-gpus>) to use in your notebook.
Here we recommend using 1 GPU.
To launch your notebook, run the following command:
You can then reach your notebook’s URL once the notebook is running.
Accessing the notebooks
Once our AI examples repository has been cloned in your environment, find your notebook by following this path: ai-training-examples > notebooks > computer-vision > image-segmentation > tensorflow > brain-tumor-segmentation-unet > notebook_image_segmentation_unet.ipynb.
A preview of this notebook can be found on GitHub here.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
