The purpose of this tutorial is to show how it is possible to train a model in order to classify sounds. To do this, we take as an example a dataset of marine mammals' sounds.
- An AI Notebooks project created inside a Public Cloud project in your OVHcloud account
- A user for AI Notebooks
- Two Object Storage containers to store the data and the model
- Your own dataset
Uploading your dataset on Public Cloud Storage
If you want to upload it from the OVHcloud Control Panel, go to the Object Storage section via the Public Cloud menu and create a new object container by + Create an object container.
In the OVHcloud Control Panel, you can upload files but not folders. For instance, you can upload a .zip file to optimize the bandwidth, then unzip it later when accessing it through your JupyterLab. You can also use the OVHcloud AI CLI to upload files and folders (and be more stable than through your browser).
If you want to run it with the CLI, just follow this guide. You have to choose the region, the name of your container, and the path where your data is located, and use the following command:
This tutorial has been completed with the Best of Watkins Marine Mammal Sound Database. If you don't have your own dataset, you can use it by downloading the dataset on Hugging Face.
Launching and accessing Jupyter notebook with "One image to rule them all" framework
NOTE: Although this tutorial is based on the use of the TensorFlow image, we advise you to use this image: One image to rule them all. This will help you avoid errors when installing libraries such as Librosa or SoundFile, and Python audio libraries.
You need to attach a volume if your data is in your OVHcloud Object Storage and you want to use it during your experiment. For more information on data, volumes and permissions, see our guide on data.
To be able to use the source code below in this article you have to create two Object Storage containers and a git repository mounted as follows:
- mount point name:
/workspace/data, permissions:read & write - mount point name:
/workspace/saved_model, permissions:read & write - mount point name:
/workspace/ai-training-examples, permissions:read & write, Git URL:https://github.com/ovh/ai-training-examples.git
Choose the same region as your object container > "One image to rule them all" framework > Attach Object Storage containers (the one that contains your dataset)
If you want to launch it with the CLI, choose the volume you want to attach and the number of GPUs (<nb-gpus>) to use on your notebook and use the following command:
For example:
You can then reach your notebook’s URL once the notebook is running.
Find the notebook by following this path: ai-training-examples > notebooks > audio > audio-classification > notebook-marine-sound-classification.ipynb.
Experimenting classification sound notebook
Once your dataset is ready and uploaded, you can train the model!
A preview of this notebook can be found on GitHub here.
- If you want to train your model, check out this tutorial.
- You can also compare two methods for audio classification tasks by following this tutorial.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
