Learn how to connect to a MySQL database instance with a Command Line Interface (CLI).
Cloud Databases allow you to focus on building and deploying cloud applications while OVHcloud takes care of the database infrastructure and maintenance in operational conditions.
- A Public Cloud project in your OVHcloud account
- A MySQL database running on your OVHcloud Cloud Databases (this guide can help you to meet this requirement)
- Configure your MySQL instance to accept incoming connections
Concept
To interact correctly with the MySQL instance, we need to first install something called a MySQL client to connect and control the MySQL service remotely. It's a Client-Server interaction.
Installing the MySQL client
Please note that a MySQL client is natively integrated in the MySQL software package, but it does not allow the use of Service URI.
You first need to install software to interact with your MySQL instance remotely. This official software can be installed on various client machines such as your own computer, a VPS, or a virtual machine. The only rule is to be able to reach the public network (Internet) and have sufficient rights to install it.
To do so, and depending on your configuration, you may need to follow official MySQL documentation to install MySQL Shell (mysqlsh), more powerful compared to MySQL Client (mysql).
MySQL Shell is not mandatory, but much more convenient to use compared to standard MySQL Clients, since you can connect with Service URI instead of individual parameters.
Follow the steps here after selecting Windows, macOS, or Linux as the operating system.
We are now ready to learn how to connect to our MySQL instance.
Configuration
We will now follow official MySQL documentation to perform our first connection.
In your CLI, type mysqlsh --version
. The result should look like this:
laptop$mysqlsh --version /snap/mysql-shell/29/bin/mysqlsh Ver 8.0.23 for Linux on x86_64 - for MySQL 8.0.23 (Source distribution)
It means that mysqlsh is correctly installed and working properly. If you do not see something like this result, please go back to the previous step and reinstall the MySQL shell.
Connect to your MySQL instance
We will follow the official MySQL documentation.
To perform a connection, simply type mysqlsh --sql
followed by the Service URI:
laptop$mysqlsh --sql "mysql://<username>:<password@<hostname>t<port>/defaultdb?ssl-mode=REQUIRED"
Don't forget you need to modify the username, password, hostname, and port.
This information can be found in the OVHcloud Control Panel in the Connection information section.
In our example, it will look like this:
laptop$mysqlsh --sql "mysql://avnadmin:Mysup3rs3cur3p4ssw0rd@mysql-ab123456-cd7891011.database.cloud.ovh.us:20184/defaultdb?ssl-mode=REQUIRED"
Once connected correctly, you should see something similar to:
MySQL Shell 8.0.23 Copyright (c) 2016, 2021, Oracle and/or its affiliates. Oracle is a registered trademark of Oracle Corporation and/or its affiliates. Other names may be trademarks of their respective owners. Type '\help' or '\?' for help; '\quit' to exit. WARNING: Using a password on the command line interface can be insecure. Creating a Classic session to '.(removed)..:20184/defaultdb?ssl-mode=REQUIRED' Fetching schema names for autocompletion... Press ^C to stop. Fetching table and column names from `defaultdb` for auto-completion... Press ^C to stop. Your MySQL connection id is 50811 Server version: 8.0.26 Source distribution Default schema set to `defaultdb`. mysql-sql [defaultdb]>
Congratulations! You are now fully able to interact with your MySQL instance!
MySQL client usage
Once connected, you can manage your MySQL instance with built-in MySQL client methods.
Please follow the official MySQL documentation.
To verify:
SHOW DATABASES;
will list all the databases; -
\h CREATE DATABASE
will display information about creating a new database.
mysql-sql [defaultdb] SHOW DATABASES; +--------------------+ | Database | +--------------------+ | defaultdb | | information_schema | | mysql | | performance_schema | | sys | +--------------------+ 5 rows in set (0.0046 sec)
defaultdb= \h CREATE DATABASE Command: CREATE DATABASE Description: create a new database Syntax: CREATE DATABASE name [ [ WITH ] [ OWNER [=] user_name ] [ TEMPLATE [=] template ] [ ENCODING [=] encoding ] [ LOCALE [=] locale ] [ LC_COLLATE [=] lc_collate ] [ LC_CTYPE [=] lc_ctype ] [ TABLESPACE [=] tablespace_name ] [ ALLOW_CONNECTIONS [=] allowconn ] [ CONNECTION LIMIT [=] connlimit ] [ IS_TEMPLATE [=] istemplate ] ] URL: https://www.mysql.org/docs/13/sql-createdatabase.html
Visit the GitHub examples repository to find out how to connect to your database with several languages.
