Learn how you can easily configure, manage, and start replicating Pure Storage FlashBlade S3™*-compatible objects to OVHcloud Object Storage.
This guide aims to help you configure and use OVHcloud Object Storage as a replication target for Pure Storage Flashblade unified storage platform.
- An OVHcloud Object Storage container/bucket (get started with this guide)
- A user with the required access rights on the bucket
- Your Object Storage credentials (
access_keyandsecret_access_key)
Create an S3-compatible Target Connection
- Sign in to the PureStorage FlashBlade GUI.
- Go to the
Storagesection and thenArray. - Click the
+button next toS3 Target Connectionsto create a Target Connections cloud object storage. - Name the connection (for example,
OVHCLOUD_OBJECT_STORAGE) and add the associated OVHcloud Object Storage endpoints in theAddressfield.
The list of all OVHcloud Object Storage endpoints can be found here.
Add Remote Cloud Object Storage Credentials
- Go to the
Protectionsection and then click onObject Replica Links. - Click the
+button to add remote credentials for object replication. - Select
OVHCLOUD_OBJECT_STORAGEfor Remote Array. - Add the name of your connection (for example,
OVHcloud_credentials), and add your Access and Secret keys from the OVHcloud Control Panel. - Confirm by clicking on
Create, and your remote credentials will be created.
Create a bucket that will be replicated to OVHcloud Object Storage
- If not already done, go to the
Storagesection, thenObject Storage, and finallyAccountsto create the account. - Configure the different parameters:
account name,quota limit, andbucket default quota limitto create the account. - Click the
Bucketssection and select the account name. - Enter a bucket name
OVHcloud-source-2025and click onCreate.
Set up the Bucket Replication to OVHcloud Object Storage
- Go to
Protection>Object ReplicationandBucket Replication Link. - Click the
+button to create a bucket replica link. - Select the bucket you just created.
- Select
OVHCLOUD_OBJECT_STORAGEfor Remote Array. - Add the name of your OVHcloud Object Storage bucket:
OVHcloud-dest-2025. - Add your remote credentials:
OVHcloud_credentials. The bucket replica link will be created. - You can now test and validate the bucket replication from Pure Storage Flashblade platform to OVHcloud Object Storage.
For more information and tutorials, please see our other Object Storage support guides or explore the guides for other OVHcloud products and services.
*S3 is a trademark filed by Amazon Technologies, Inc. OVHcloud's service is not sponsored by, endorsed by, or otherwise affiliated with Amazon Technologies, Inc.
