Learn how to optimize your OVHcloud Object Storage costs by configuring lifecycle rules for automatic expiration, transition, and cleanup of objects.
This feature is not supported on the legacy .perf endpoint and is only available through the .io endpoint. For more information about the differences between the two endpoints, see this documentation.
Introduction
What is lifecycle?
OVHcloud Object Storage bucket lifecycle is a feature that allows you to optimize your storage costs by managing your objects throughout their lifecycle. By uploading a lifecycle configuration to a bucket, you define a set of rules that the object storage solution applies to the objects of the said bucket to perform specific actions.
There are two types of actions that OVHcloud Object Storage performs on your objects:
- expiration: These actions determine when your objects expire. Expired objects are then automatically deleted.
- transition: These actions determine when your objects are transitioned to a lower-cost storage tier. For instance, you might want to transition your objects stored in the High Performance tier to the Standard tier after 30 days.
Examples of use cases
By leveraging the lifecycle configuration feature, you can tell OVHcloud Object Storage to:
- clean incomplete multi-part uploads: Suppose you have uploaded a large number of large (>5GB) objects using multi-part uploads, but for some reason, for many objects, the multi-part upload did not complete successfully. In this scenario, even if you haven't fully uploaded all the parts of an object, you still have to pay for the storage cost of the uploaded parts. In that case, you might want to clean the parts of all the incomplete multi-part uploads to save money.
- clean old unused data: Suppose you have an application that stores its logs in a bucket. Your organization might define a log retention policy of 30 days. After that, the logs are no longer needed, and you might want to delete them to save money.
- optimize storage costs by transitioning infrequently accessed data to a less expensive storage tier: Suppose you have certain files that are often used for a brief duration before they are hardly used again. You might not require immediate access, but your organization or laws may require that you keep them for a certain period. After that, you can delete them to save money.
Special considerations
When an object reaches the end of its lifetime based on its lifecycle configuration, the result of transition or expiration actions performed by OVHcloud Object Storage varies according to the versioning state of the bucket:
- non-versioned: There is only one existing version of the object, which is the current version, and it is deleted permanently.
- versioned: A delete marker is created and becomes the current version. You can also choose how many old versions you want to keep. If the current object version is the only object version, and it is also a delete marker, that delete marker will be removed.
- versioning-suspended: We currently do not allow for the suspension of versioning if you have a lifecycle configuration in effect and vice versa. We currently do not allow for the upload of a lifecycle configuration if versioning is suspended on the bucket.
Expiration
Lifecycle rules are processed asynchronously and on a best-effort basis. Most rules are applied within 24 hours, but for very large buckets or when processing many objects, it might take longer. During this delay, you continue to be billed for the object's current storage tier, even if the rule (e.g., expiration or transition) has already been triggered but not yet completed. For example, if an object is set to be deleted on day 30, but is only processed on day 32, you may be billed for an additional two days.
Conflicting expiration dates
Typically, the lifecycle feature is designed to help you optimize your storage costs. For instance, if two expiration rules overlap, i.e, they target the same set of objects but with different expiration dates, the rule with the shorter duration is applied, ensuring that data is not retained beyond the anticipated timeframe: OVHcloud Object Storage always tries to choose the most cost-effective path for you.
Generally speaking, when you have multiple rules in a bucket lifecycle configuration that apply to the same set of objects:
- Permanent deletion takes precedence over transition.
- Transition takes precedence over the creation of delete markers.
- The shorter expiration/transition date takes precedence over the longer one.
Current vs noncurrent versions
In a versioning-enabled bucket, each object has one current version and zero or more noncurrent versions. When you delete an object:
- If you don't specify a version ID in your delete request, a delete marker is created instead of deleting the object. The current object version becomes noncurrent, and the delete marker becomes the current version.
- If you specify a version ID in your delete request, the version of the object that is specified is permanently deleted (a delete marker is not created).
- A delete marker with zero noncurrent versions is called an expired object delete marker.
Configuration
Version 1 of lifecycle configuration (with Prefix attribute outside of Filter) is deprecated. We tolerate version 1 by automatically transforming the json to match version 2 format. However, we strongly advise you to use only version 2 as described below.
Click here for the basic structure of a lifecycle configuration JSON containing expiration rules.
| Attribute | Required | Description |
| Rules | yes | Array of lifecycle rules. |
| ID | yes | A unique id for a lifecycle rule. |
| Status | yes | Tells if a lifecycle rule is enabled or disabled. |
| Filter | yes | A filter that identifies the subset of objects to which the replication rule applies. To replicate all objects in the bucket, specify an empty object. |
| Filter.Prefix | no | An object key name prefix that identifies the object or objects to which the rule applies. To include all objects in a bucket, specify an empty string. |
| Filter.Tag | no | Filter the objects by tag key and/or value. |
| Filter.Tag.Key | no | Key of the tag filter. |
| Filter.Tag.Value | no | Value of the tag filter. |
| Filter.ObjectSizeGreaterThan | no | Minimum object size to which the rule applies. |
| Filter.ObjectSizeLessThan | no | Maximum object size to which the rule applies. |
| Filter.And | no | You can apply multiple selection criteria in the filter. A logical AND applies to multiple filter criteria. |
| Filter.And.Tags | no | An array of tag filters. All of the tags of the array must exist in the object's tag set in order for the rule to apply. |
| Expiration | yes* | A lifecycle action that applies a deletion operation to the set of filtered objects. ⚠️ Mandatory if Transitions or AbortIncompleteMultipartUpload is not present |
| Expiration.Date | no* | Indicates the deletion date of the objects. The date value must be in the ISO 8601 date format and the time must always be set to midnight UTC. ⚠️ This attribute is not mandatory if Days is present. ⚠️ this attribute is mutually exclusive with Days i.e you either have Date or Days but you cannot specify both. |
| Expiration.Days | yes* | Indicates the duration in days after which the objects are to be deleted. The value must be an integer equal to or greater than 1. ⚠️ This attribute is mandatory if Date is not present. ⚠️ this attribute is mutually exclusive with Date i.e you either have Date or Days but you cannot specify both. |
| Expiration.ExpiredObjectDeleteMarker | no | Tells if OVHcloud Object Storage should immediately remove delete markers with no noncurrent versions aka expired delete markers. ⚠️ You cannot specify Days or Date with ExpiredObjectDeleteMarker in the same rule. When you specify the Days/Date, expired delete markers are automatically deleted like normal objects when they satisfy the age criteria. ExpiredObjectDeleteMarker is used to clean up delete markers as soon as they become the only version, you have to create a separate rule with only ExpiredObjectDeleteMarker attribute in Expiration. ⚠️ When you use the ExpiredObjectDeleteMarker lifecycle action, the rule cannot specify a tag-based filter. |
| NoncurrentVersionExpiration | no | A lifecycle action that indicates when noncurrent object versions should be deleted. This action does not affect the current versions. It only deletes the versions that are not current. |
| NoncurrentVersionExpiration.NoncurrentDays | no | Indicates the number of days before a noncurrent version is eligible for deletion after it became noncurrent, i.e., the minimum age of a noncurrent version. |
| NoncurrentVersionExpiration.NewerNoncurrentVersions | no | Indicates the number of most recent noncurrent versions to retain. Maximum is 100. Example: Suppose you have an object B with 10 versions: - B v10 (current version, creation date: 2024-10-23) - B v9 (noncurrent version, creation date: 2024-10-22) - B v8 (noncurrent version, creation date: 2024-10-21) - B v7 (noncurrent version, creation date: 2024-10-20) - B v6 (noncurrent version, creation date: 2024-10-19) - B v5 (noncurrent version, creation date: 2024-10-18) - B v4 (noncurrent version, creation date: 2024-10-17) - B v3 (noncurrent version, creation date: 2024-10-16) - B v2 (noncurrent version, creation date: 2024-10-15) - B v1 (noncurrent version, creation date: 2024-10-14) If NewerNoncurrentVersions=3, the lifecycle rule will delete all the noncurrent versions except the 3 most recent i.e v9, v8 and v7. |
| AbortIncompleteMultipartUpload | no | A lifecycle action that applies a delete operation on parts of an incomplete multipart upload. |
| AbortIncompleteMultipartUpload.DaysAfterInitiation | no | Indicates the number of days after which all the parts of all incomplete multipart uploads are deleted and aborts the underlying multipart uploads. |
Understanding the NoncurrentDays parameter
The NoncurrentDays parameter defines the minimum number of days since a version is no longer current. This parameter must not be confused with the age of the object, but rather indicates the minimum age of a noncurrent version.
Example 1:
Suppose you have an object A with 10 versions:
- A v10 (current version, creation date: 2024-10-23).
- A v9 (noncurrent version, creation date: 2024-10-22).
- A v8 (noncurrent version, creation date: 2024-10-21).
- A v7 (noncurrent version, creation date: 2024-10-20).
- A v6 (noncurrent version, creation date: 2024-10-19).
- A v5 (noncurrent version, creation date: 2024-10-18).
- A v4 (noncurrent version, creation date: 2024-10-17).
- A v3 (noncurrent version, creation date: 2024-10-16).
- A v2 (noncurrent version, creation date: 2024-10-15).
- A v1 (noncurrent version, creation date: 2024-10-14).
If current date is 2024-10-23 and NoncurrentDays=5, the lifecycle rule will delete the noncurrent versions older than 5 days, i.e, v1, v2, v3, and v4 because:
- A v1 is noncurrent since 2024-10-15 (when A v2 was created), i.e, its age as a noncurrent version is 8 days.
- A v2 is noncurrent since 2024-10-16 (when A v3 was created), i.e, its age as a noncurrent version is 7 days.
- A v3 is noncurrent since 2024-10-17 (when A v4 was created), i.e, its age as a noncurrent version is 6 days.
- A v4 is noncurrent since 2024-10-18 (when A v5 was created), i.e its age as a noncurrent version is 5 days.
Example 2:
Suppose you have an object B with 5 versions:
- B v5 (current version, creation date: 2024-10-28).
- B v4 (noncurrent version, creation date: 2024-10-27).
- B v3 (noncurrent version, creation date: 2024-10-20).
- B v2 (noncurrent version, creation date: 2024-10-15).
- B v1 (noncurrent version, creation date: 2024-10-14).
If current date is 2024-10-29 and NoncurrentDays=5, the lifecycle rule will delete the noncurrent versions older than 5 days, i.e, only v1 and v2 because:
- B v1 is noncurrent since 2024-10-15 (when B v2 was created), i.e, its age as a noncurrent version is 14 days.
- B v2 is noncurrent since 2024-10-20 (when B v3 was created), i.e, its age as a noncurrent version is 9 days.
Get the scheduled expiration date
If an object is scheduled to be deleted, a HEAD-OBJECT call will return a special http response header x-amz-expiration that contains a timestamp indicating its expiry date and an ID of the lifecycle rule that has been applied.
The header format is: x-amz-expiration: expiry-date=<timestamp>, rule-id=<rule_id>
- expire-date: is obtained by adding the creation date and the delay from expiration
- rule-id: the matched rule id triggering the deletion
Example: Get expiration date via direct http API call
Example: Get expiration date via the cli
Examples of expiration configurations
Delete all objects in a non-versioned bucket
Since the bucket is non-versioned, the following configuration will permanently delete all objects in the bucket after 1 day. However, if you have incomplete multipart uploads, they will not be deleted; to completely empty your bucket, you will need additional rules.
Abort incomplete multipart uploads
The following configuration will direct OVHcloud Object Storage to abort all incomplete multipart uploads identified by the prefix "/mpus" and delete the parts already uploaded within 7 days after their initiation:
Expire objects in a non-versioned bucket with overlapping prefixes
In the following configuration, there are 2 lifecycle rules:
- The rule "123456" permanently deletes all objects prefixed "old" 30 days after their creation.
- The rule "456789" permanently deletes all objects prefixed "old/logs" 65 days after their creation.
The same set of objects is eligible for both lifecycle rules. In this case, the first rule will apply after 30 days, and the second rule will then be ignored because the objects will have already been removed.
Expire objects in a non-versioned bucket with overlapping tags
In the following configuration, there are two lifecycle rules:
- The rule "123456" permanently deletes all objects tagged "age" with value "old" 30 days after their creation.
- The rule "456789" permanently deletes all objects tagged "type" with value "logs" 65 days after their creation.
If an object has both tags, i.e, if an object is tagged "age" with value "old" and "type" with value "logs", the first rule will apply after 30 days, and the second rule will then be ignored because the object will have already been removed.
Expire objects in a versioned bucket
In a versioned bucket, the following configuration performs the following actions:
- after 45 days, it automatically expires all the objects with prefix "old/" by creating delete markers for each of the current object versions: the current version becomes noncurrent, and the delete marker becomes the current version.
- all 15+ days old noncurrent versions of the selected objects are then deleted except for the 3 most recent noncurrent versions. If there are less than three noncurrent versions, the NoncurrentVersionExpiration action will not be applied.
Empty a versioned bucket
In the following configuration, there are 3 lifecycle rules:
- the 1st rule will expire (insert a delete marker) current version of all objects 1 day after their creation date, and will permanently delete all non-current versions 1 day after they become non-current
- the 2nd rule will automatically delete any expired delete markers
- the 3rd rule will automatically delete all incomplete multipart uploads 1 day after their creation date
Transition
Supported transitions
NOTE: Only transitions from a higher cost storage tier to a lower-cost storage tier are allowed. Additionally, all transitions to Cold Archive are currently not supported.
The following are the currently supported transitions:
| from/to | High Performance | Standard | Infrequent Access |
| High Performance | - | yes | yes |
| Standard | forbidden | - | yes |
| Infrequent Access | forbidden | forbidden | - |
Minimum object size
OVHcloud Object Storage will prevent any transition to any storage tier for objects smaller than 128KB. However, you can allow transitions and expirations for smaller objects by using ObjectSizeGreaterThan or ObjectSizeLessThan parameters to filter with a minimum size or maximum size. In the following example, objects smaller than 128KB are also allowed to transition to Standard class.
Minimum transition delay
The minimum duration for transition rules is 1 day i.e your lifecycle configuration will not be valid and you will get an error if the number of days for your transition rule is less than 1 day. In practice, with multiple transitions, the minimum duration for the nth transition must be at least n days.
For example:
- with a single transition from High Performance to Standard, the minimum duration is 1 day.
- you have multiple transitions: 1) from High Performance to Standard and 2) from Standard to Infrequent Access. The minimum durations are 1 day (1st transition) and 2 days (2nd transition); a third transition would be 3 days, a fourth transition would be 4 days, and so on.
Expiration vs transitions
As already mentioned before, when you have multiple rules in a bucket lifecycle configuration that apply to the same set of objects:
- Transition takes precedence over creation of delete markers
Configuration
The following is the basic structure of a lifecycle configuration JSON containing transition rules:
| Transitions | yes* | An array of lifecycle operations that automatically copy all selected objects (current versions only, if versioning is enabled) from their current storage tier to the most effective storage tier. |
| Transitions.Date | no* | Indicates the date when the objects are to be transitioned. The date value must be in the ISO 8601 date format and the time must always be set to midnight UTC. ⚠️ This attribute is not mandatory if Days is present. ⚠️ This attribute is mutually exclusive with Days, i.e, you either have Date or Days, but you cannot specify both. |
| Transitions.Days | yes* | Indicates the duration in days after which the objects are to be transitioned. The value must be an integer equal to or greater than 1. ⚠️ This attribute is mandatory if Date is not present. ⚠️ This attribute is mutually exclusive with Date, i.e, you either have Date or Days, but you cannot specify both. |
| Transitions.StorageClass | yes | Indicates the target Storage class. Currently, only "STANDARD" is available. |
| NoncurrentVersionTransitions | no | An array of lifecycle actions that indicate when noncurrent object versions should be transitioned. These actions do not affect the current versions. They only transition the versions that are not current. |
| NoncurrentVersionTransitions.NoncurrentDays | no | Indicates the number of days before a noncurrent version is eligible to transition after they became noncurrent i.e the minimum age of a noncurrent version. |
| NoncurrentVersionTransitions.NewerNoncurrentVersions | no | Indicates the number of most recent noncurrent versions to retain in their current storage tier. Maximum is 100. |
Examples of transition configurations
Transition objects in a non-versioned bucket
The following configuration will transition all objects with prefix "old" from the High Performance storage tier to the Standard storage tier (EXPRESS_ONEZONE to STANDARD) 30 days after their creation.
Transition objects in a versioned bucket
The following configuration specifies the following actions:
- the current version of all objects will be transitioned from the High Performance tier to the Standard tier 30 days after their creation.
- if the objects have noncurrent versions, all the noncurrent versions older than 5 days will be transitioned from the High Performance tier to the Standard tier.
In this scenario, suppose you upload an object with multiple versions:
- v5 (current version, creation date 2024-10-23)
- v4 (current version, creation date 2024-10-23)
- v3 (current version, creation date 2024-10-22)
- v2 (current version, creation date 2024-10-18)
- v1 (current version, creation date 2024-10-17)
If the current date is 2024-10-23:
- v5 will be transitioned 30 days after 2024-10-23
- v1 will be transitioned 30 days after its creation date (2024-10-17)
Mix of expiration and transition
The following lifecycle configuration applies to all objects with prefix "old" and tag "type" with value "logs". It specifies the following actions:
- 30 days after their creation, the objects will be transitioned from High Performance to Standard tier.
- 90 days after their creation, the objects will be deleted.
In this scenario, the objects will be stored in the High Performance tier for 30 days and then 60 days in the Standard tier before being finally deleted.
Mix of expiration and transition rules with conflicting rules
The following lifecycle configuration is uploaded to a non-versioned bucket. It defines 2 rules that apply to all objects with prefix "old" and tag "type" with value "logs":
- 90 days after their creation, the objects will expire
- 90 days after their creation, the objects will be transitioned
In this scenario, two rules direct OVHcloud Object Storage to perform two different actions on the same set of objects at the same time. Since permanent deletion takes precedence over transition, the objects are removed after 90 days, and there is no further point in changing the storage class.
Using the CLI
As a prerequisite, you must have a bucket containing data on which you want to apply the lifecycle configuration and have the necessary permissions (by default the bucket owner or the s3:putLifecycleConfiguration permission given via a user access policy) to do so.
Create a lifecycle configuration file using your favorite editor.
Example: Expire objects with specific prefix in a versioned bucket.
The following configuration does the following actions:
- all 15+ days old noncurrent versions of the selected objects are then deleted except for the 3 most recent noncurrent versions. If there are less than 3 noncurrent versions, the NoncurrentVersionExpiration action will not be applied.
Upload the file to the bucket:
Using the OVHcloud Control Panel (coming soon)
FAQ
Why are my objects not expired yet, even though I set up lifecycle rules?
Why is the object count of my versioning-enabled bucket still increasing, even though I set up lifecycle rules?
When a delete object operation (i.e, expiration) is performed on an object in a versioning-enabled bucket, it does not delete the object permanently, but it creates a delete marker on the object. This delete marker becomes the latest and current version of the object with a new version ID, thus increasing the object count of the bucket.
Extra lifecycle configuration is needed to remove objects permanently, including incomplete multipart uploads, expired delete markers, and previous versions of objects.
How can I empty my S3™* bucket using Lifecycle rules?
To empty an S3 bucket, you will need to consider the following:
- expire current versions of objects
- remove previous versions of objects
- remove expired delete markers
- remove incomplete multipart uploads
How can I monitor actions taken by my lifecycle rules?
You can use the Server Access Logging feature to monitor actions taken by your lifecycle rules on your S3 bucket. Server Access Logging provides detailed records for the requests that are made to a bucket including expiration operations, transitions of objects to another storage tier, etc.
How can I recover objects deleted by my lifecycle rules?
Versioning is the only way to recover objects that have expired by lifecycle rules. It must be activated on your bucket before you set up your lifecycle rules. However, objects that are permanently deleted by lifecycle rules cannot be recovered.
How can I exclude prefixes from my lifecycle rules?
Prefix exclusion is not supported.
I have set up replication rules between two S3 buckets: why are objects deleted in my source bucket rather than the destination bucket?
Delete operations resulting from application of lifecycle rules are not replicated. See the documentation for asynchronous replication for further details on what is replicated and what is not.
For more information and tutorials, please see our other Public Cloud support guides or explore the guides for other OVHcloud products and services.
*S3 is a trademark filed by Amazon Technologies, Inc. OVHcloud's service is not sponsored by, endorsed by, or otherwise affiliated with Amazon Technologies, Inc.
