Learn how to connect to a MongoDB database instance with one of the world's most famous Open Source (SSPL) management tools for MongoDB: MongoDB Compass.
Managed Databases (also called Cloud Databases) allow you to focus on building and deploying cloud applications while OVHcloud takes care of the database infrastructure and maintenance in operational conditions.
- A Public Cloud project in your OVHcloud account
- A MongoDB database running on your OVHcloud Cloud Databases (this guide can help you to meet this requirement)
- Configure your MongoDB instance to accept incoming connections
- A MongoDB Compass stable version installed and public network connectivity (Internet)
Concept
A MongoDB instance can be managed in multiple ways. One of the easiest and most powerful is to use a Command Line Interface (CLI), as shown in our guide: Connect to MongoDB with CLI or by using programming languages, such as PHP or Python.
Another way is to interact directly using a management tool for MongoDB: MongoDB Compass.
To do so, we will need to install MongoDB Compass, configure our Cloud Databases for MongoDB instances to accept incoming connections, and finally configure MongoDB.
Installation
Please follow the official documentation to install MongoDB Compass.
We are now ready to learn how to connect to our MongoDB instance.
Connect with MongoDB Compass
In MongoDB Compass, fill in the URI field with your service URI and click Connect
Now you can interact with your Cloud Databases for MongoDB:
Insert and Query Data
You can use the mongoshell, integrated into Compass, to create your first database and collection. Below is a script that creates the database company and collection customer and inserts 100 random documents.
Load Data into MongoDB
To load 100 documents into a collection called customer
with random data, use the following mongosh
script:
Query Data with the Aggregation Framework
The MongoDB aggregation pipeline below uses the MongoDB Aggregation Framework to group customers by age and count each occurrence. You can use the mongoshell to execute:
You can also use the UI with Compass to execute the aggregation pipeline.
Visit the GitHub examples repository to find out how to connect to your database in several languages.
