Learn how to connect to a Valkey service with one of the world's most famous programming languages: Python.
Cloud Databases allow you to focus on building and deploying cloud applications while OVHcloud manages the database infrastructure and maintenance in operational conditions.
You can find an example in the GitHub examples repository.
- A Public Cloud project in your OVHcloud account
- A Valkey service running on your OVHcloud Cloud Databases (this guide can help you to meet this requirement)
- Configure your Valkey service to accept incoming connections
- A working Python environment
Concept
A Valkey service can be managed in multiple ways. One of the easiest, yet powerful, is to use a Command Line Interface (CLI), as shown in our guide: Connect with CLI.
Another way is to interact directly using programming languages, such as Python.
We will need to set up our Python environment with the redis-py client, then code in Python to perform a few example actions.
Set up your Python environment
To interact with your instance using Python, your development environment needs to be configured with:
- A compatible version of Python
- Redis-py
Please follow the official Redis-py to get the latest information.
Once your Python environment is set up and you begin executing a python --version in your command line interface (CLI), you should see information about the version as shown below:
In the same console, by typing a pip list, check if redis-py is correctly installed:
We are now ready to learn how to connect to our instance!
Connect with redis-py
In your Python environment, let's try a connection. To be sure that we are indeed connected, set a data pair and then check that we can get the value of it.
redis-connect.py
Congratulations! Everything is working properly.
