This tutorial explains the following Load Balancer configurations:
- Deploying a basic HTTP Load Balancer Private → Private
- Deploying a basic HTTP Load Balancer Public → Private
- A Public Cloud project in your OVHcloud account
- A private network configured in your project
- Prepare the environment to use the OpenStack API
- Set OpenStack environment variables
- OpenStack Octavia client installed
Load Balancer within your Private Network (Private → Private)
When you create a Load Balancer, by default it gets a private IP in the private network selected during its creation.
We want to balance the load between the two backends: backend--1 and backend--2.
(os_client) ~ openstack server list +--------------------------------------+------------+--------+-----------------------------------------------------------------------+--------------+--------+ | ID | Name | Status | Networks | Image | Flavor | +--------------------------------------+------------+--------+-----------------------------------------------------------------------+--------------+--------+ | 5b8c722b-57d0-460a-b2c0-b0a681bf4e52 | backend--2 | ACTIVE | priv-net=10.0.111.243 | Ubuntu 20.04 | d2-4 | | 9a43ce4c-e0fe-4a54-81f5-aad3ac6f8e88 | backend--1 | ACTIVE | priv-net=10.0.112.172 | Ubuntu 20.04 | d2-4 | | 67b9372e-bf08-4c57-9945-42b07dbfcd36 | bastion | ACTIVE | Ext-Net=2001:48f0:163:100::1662, 169.254.10.150; priv-net=10.0.109.243 | Ubuntu 20.04 | d2-8 | +--------------------------------------+------------+--------+-----------------------------------------------------------------------+--------------+--------+
Step 1: Create the Load Balancer
openstack loadbalancer create --name loadbalancer_private_to_private --vip-subnet-id <private_subnet_id> +---------------------+--------------------------------------+ | Field | Value | +---------------------+--------------------------------------+ | admin_state_up | True | | availability_zone | None | | created_at | 2022-06-29T12:24:35 | | description | | | flavor_id | e8945800-98ae-470d-929c-c49035c892a2 | | id | 4db76fce-f8f7-435f-8031-716f82a7f1dc | | listeners | | | name | loadbalancer_private_to_private | | operating_status | OFFLINE | | pools | | | project_id | 96575fa614c14aa7b001c7e121d772f2 | | provider | amphora | | provisioning_status | PENDING_CREATE | | updated_at | None | | vip_address | 10.0.3.50 | | vip_network_id | d20943ed-5159-4805-b48a-2375dd93e480 | | vip_port_id | 631f240c-16f7-483f-b1c4-6eff7a8adcf4 | | vip_qos_policy_id | None | | vip_subnet_id | 4ecfca39-6e87-496a-8692-2e7f43bf7767 | | tags | | +---------------------+--------------------------------------+
--flavor during the creation, the Load Balancer will be of a small size.Use the following command to display the Octavia flavors in OpenStack:
❯ openstack loadbalancer flavor list +--------------------------------------+--------+--------------------------------------+---------+ | id | name | flavor_profile_id | enabled | +--------------------------------------+--------+--------------------------------------+---------+ | e8945800-98ae-470d-929c-c49035c892a2 | small | 31176316-717b-4c4c-9f76-db1581f1046d | True | | dda42c9b-afc7-46fc-819f-ca5fb01e45ed | medium | 50eccffd-6b30-4051-81d6-49938cc4cbf7 | True | | d32c07b7-2d7b-4dfe-85c6-4dfeef9e6cf5 | large | 96315536-335b-4a8a-afc7-fde1fb6959a7 | True |
| 15c9ee6e-5ffa-45ca-a521-3615ae19575c | xl | 9d6890f8-5ea5-48f5-b771-14005b590b54 | True | +--------------------------------------+--------+--------------------------------------+---------+
For the next configuration, you will have to wait until the
provisioning_status becomes ACTIVE.You can already see when creating our Load Balancer that it is associated with a Virtual IP address (VIP).
This will be our Load Balancer IP inside our Private Network.
Step 2: Create a listener
openstack loadbalancer listener create --protocol-port 80 --protocol HTTP --name listener <loadbalancer_id> +-----------------------------+--------------------------------------+ | Field | Value | +-----------------------------+--------------------------------------+ | admin_state_up | True | | connection_limit | -1 | | created_at | 2022-06-29T12:34:37 | | default_pool_id | None | | default_tls_container_ref | None | | description | | | id | e2e67b80-61e6-43bd-b1f1-703ab1abc7af | | insert_headers | None | | l7policies | | | loadbalancers | 4db76fce-f8f7-435f-8031-716f82a7f1dc | | name | listener | | operating_status | OFFLINE | | project_id | 96575fa614c14aa7b001c7e121d772f2 | | protocol | HTTP | | protocol_port | 80 | | provisioning_status | PENDING_CREATE | | sni_container_refs | [] | | timeout_client_data | 50000 | | timeout_member_connect | 5000 | | timeout_member_data | 50000 | | timeout_tcp_inspect | 0 | | updated_at | None | | client_ca_tls_container_ref | None | | client_authentication | NONE | | client_crl_container_ref | None | | allowed_cidrs | None | | tls_ciphers | None | | tls_versions | None | | alpn_protocols | None | | tags | | +-----------------------------+--------------------------------------+
Step 3: Create the pool
❯ openstack loadbalancer pool create --name pool --lb-algorithm ROUND_ROBIN --listener <listener_id> --protocol HTTP +----------------------+--------------------------------------+ | Field | Value | +----------------------+--------------------------------------+ | admin_state_up | True | | created_at | 2022-06-29T12:41:52 | | description | | | healthmonitor_id | | | id | f0c833f7-53bb-46b7-8818-637d89a68089 | | lb_algorithm | ROUND_ROBIN | | listeners | e2e67b80-61e6-43bd-b1f1-703ab1abc7af | | loadbalancers | 4db76fce-f8f7-435f-8031-716f82a7f1dc | | members | | | name | pool | | operating_status | OFFLINE | | project_id | 96575fa614c14aa7b001c7e121d772f2 | | protocol | HTTP | | provisioning_status | PENDING_CREATE | | session_persistence | None | | updated_at | None | | tls_container_ref | None | | ca_tls_container_ref | None | | crl_container_ref | None | | tls_enabled | False | | tls_ciphers | None | | tls_versions | None | | tags | | | alpn_protocols | None | +----------------------+--------------------------------------+
Step 4: Add the servers
❯ openstack loadbalancer member create --subnet-id <private_subnet_id> --address <server_ip_address> --protocol-port 80 <pool_id> +---------------------+--------------------------------------+ | Field | Value | +---------------------+--------------------------------------+ | address | 10.0.3.123 | | admin_state_up | True | | created_at | 2022-06-29T12:48:55 | | id | fbe34622-2538-4896-bda3-d92ca66f7a30 | | name | | | operating_status | NO_MONITOR | | project_id | 96575fa614c14aa7b001c7e121d772f2 | | protocol_port | 80 | | provisioning_status | PENDING_CREATE | | subnet_id | 4ecfca39-6e87-496a-8692-2e7f43bf7767 | | updated_at | None | | weight | 1 | | monitor_port | None | | monitor_address | None | | backup | False | | tags | | +---------------------+--------------------------------------+
Step 5: Use your Load Balancer
root@bastion:~# curl http://10.0.3.50/backend.txt Backend 1 root@bastion:~# curl http://10.0.3.50/backend.txt Backend 2
Load Balancer with a public IP (Public → Private)
We will be using the Octavia Load Balancer previously deployed in a private network and an OpenStack Floating IP.
We will need to create a Floating IP address on the public network (Ext-Net), and then associate it to the Load Balancer's VIP port.
In order to use a Floating IP, we will need to create an L3 router and configure an external Gateway on it.
What is the role of a Floating IP?
Floating IP addresses are used in the OpenStack universe to expose resources (Neutron port) to the Internet. You can associate a Floating IP to a private network port only.
You can expose two types of resources:
- An instance with a private port
- An Octavia Load Balancer Virtual IP address (VIP)
Floating IP currently does not support IPv6.
You can read more about it in our dedicated Concepts - Additional IP or Floating IP guide.
Step 1: Create the router
openstack router create <router_name>
Step 2: Add an external Gateway on your router
openstack router set --external-gateway Ext-Net <router_name>
Step 3: Attach the router to your Private Network
openstack router add subnet <router_id> <subnet_id>
Step 4: Create a Floating IP on the public network: Ext-Net
openstack floating ip create Ext-Net +---------------------+--------------------------------------+ | Field | Value | +---------------------+--------------------------------------+ | created_at | 2022-06-29T13:19:10Z | | description | | | dns_domain | None | | dns_name | None | | fixed_ip_address | None | | floating_ip_address | 169.254.10.250 | | floating_network_id | b2c02fdc-ffdf-40f6-9722-533bd7058c06 | | id | 5f1ad04e-f341-457b-a174-a1204ee4feef | | name | 169.254.10.250 | | port_details | None | | port_id | None | | project_id | 96575fa614c14aa7b001c7e121d772f2 | | qos_policy_id | None | | revision_number | 0 | | router_id | None | | status | DOWN | | subnet_id | None | | tags | [] | | updated_at | 2022-06-29T13:19:10Z | +---------------------+--------------------------------------+
Step 5: Associate its ID to the Load Balancer's VIP address
openstack floating ip set --port <load_balancer_vip_port_id> <floating_ip_id>
Step 6: Using your Load Balancer with its public IP
❯ curl http://169.254.10.250/backend.txt Backend 2 ❯ curl http://169.254.10.250/backend.txt Backend 1 ❯ curl http://169.254.10.250/backend.txt Backend 2 ❯ curl http://169.254.10.250/backend.txt Backend 1 ❯ curl http://169.254.10.250/backend.txt Backend 2
Where to place the public Gateway
The public Gateway is defined by an L3 router attached to a private network with an external Gateway.
For more information and tutorials, please see our other Public Cloud Networking support guides or explore the guides for other OVHcloud products and services.
