In this tutorial, we are using Velero to backup and restore an OVHcloud Managed Kubernetes cluster configuration and resources.
Velero is an open source tool to safely backup and restore, perform disaster recovery, and migrate Kubernetes cluster resources. It can be used for backing up volumes, but we don’t support this usage, please look at our Backing Up Persistent Volumes using Stash tutorial for our recommended alternative.
We are using our Public Cloud’s Swift Object Storage with the Swift S3 API as storage backend for Velero. Velero uses the S3 protocol to store the cluster backups on a S3 compatible object storage.
Before you begin
This tutorial presupposes that you already have a working OVHcloud Managed Kubernetes cluster, and some basic knowledge of how to operate it. If you want to know more on those topics, please look at the deploying a Hello World application documentation.
Creating the S3 bucket for Velero
Velero needs a S3 bucket as storage backend to store the data from your cluster.
In this section you will create your S3 bucket on Swift.
Prepare your working environment
Before creating your S3 bucket you need to:
You should now have access to your OpenStack RC file, with a filename line <user_name>-openrc.sh
, and the username and password for your OpenStack account.
Set the OpenStack environment variables
Set the environement variables by sourcing the OpenStack RC file:
# source <user_name>-openrc.sh
The shell will ask you for your OpenStack password:
Please enter your OpenStack Password for project <project_name> as user <user_name>:
Create EC2 credentials
S3 tokens are different, you need 2 parameters (access and secret) to generate a S3 token.
These credentials will be safely stored in Keystone. To generate them with python-openstack
client:
# openstack ec2 credentials create
Please write down the access and secret parameters:
| Field | Value
| access | 5a4d8b8d88104123a862c527ede5a3d3
| links | {u'self': u'https://auth.cloud.ovh.net/v3/users/d74d05ff121b44bea9216495e7f0df61/credentials/OS-EC2/5a4d8b8d88104123a862c527ede5a3d3'}
| project_id | 20e124b71be141299e111ec26b1892fa
| secret | 925d5fcfcd9f436d8ffcb20548cc53a2
| trust_id | None
| user_id | d74d05ff121b44bea9216495e7f0df61
Configure awscli client
Install the awscli
client:
# pip3 install awscli awscli-plugin-endpoint
Complete and write down the configuration for awscli
into ~/.aws/config
[plugins]
endpoint = awscli_plugin_endpoint
[profile default]
aws_access_key_id = <access fetched in previous step>
aws_secret_access_key = <secret fetched in previous step>
region = <public cloud region in lower case without digit>
s3 =
endpoint_url = https://s3.<public cloud region without digit>.cloud.ovh.net
signature_version = s3v4
addressing_style = virtual
s3api =
Create a S3 bucket for Velero
Create a new bucket:
# aws --profile default s3 mb s3://velero-s3
Installing Velero
We strongly recommend that you use an official release of Velero. The tarballs for each release contain the velero command-line client. Expand the tarball and add it to your PATH.
Create a Velero-specific credentials file (credentials-velero
) in your local directory:
[default]
aws_access_key_id=<AWS_ACCESS_KEY_ID>
aws_secret_access_key=<AWS_SECRET_ACCESS_KEY>
Where <AWS_ACCESS_KEY_ID>
and <AWS_SECRET_ACCESS_KEY>
and the access and secret S3 credentials generated in the precedent step.
Install Velero, including all prerequisites, into the cluster and start the deployment. This will create a namespace called velero
, and place a deployment named velero
in it.
# velero install \
--provider aws \
--plugins velero/velero-plugin-for-aws:v1.0.1 \
--bucket <your bucket name> \
--secret-file ./credentials-velero \
--backup-location-config region=<public cloud region without digit>,s3ForcePathStyle="true",s3Url=https://s3.<public cloud region without digit>.cloud.ovh.net
In my case, with the cluster in the GRA
region, that meant:
# velero install \
--provider aws \
--bucket velero-s3 \
--secret-file ./credentials/credentials-velero \
--backup-location-config region=gra,s3ForcePathStyle="true",s3Url=https://s3.gra.cloud.ovh.net
# velero install \
--provider aws \
CustomResourceDefinition/backups.velero.io: attempting to create resource
CustomResourceDefinition/backups.velero.io: created
CustomResourceDefinition/restores.velero.io: attempting to create resource
CustomResourceDefinition/restores.velero.io: created
CustomResourceDefinition/downloadrequests.velero.io: attempting to create resource
CustomResourceDefinition/downloadrequests.velero.io: created
Deployment/velero: attempting to create resource
Deployment/velero: created
Velero is installed! ⛵ Use 'kubectl logs deployment/velero -n velero' to view the status.
Now Velero is installed, you can try your first backup…
Verifying Velero is working
To verify that Velero is working correctly, let’s test with one example deployment:
- Copy the following code into a
velero-example-without-pv.yml
file:
apiVersion: v1
kind: Namespace
metadata:
labels:
app: nginx
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: nginx-example
spec:
replicas: 2
selector:
matchLabels:
app: nginx
template:
metadata:
labels:
app: nginx
spec:
containers:
- image: nginx:1.7.9
ports:
- containerPort: 80
apiVersion: v1
kind: Service
metadata:
labels:
app: nginx
spec:
ports:
- port: 80
targetPort: 80
selector:
app: nginx
type: LoadBalancer
And apply it to your cluster:
# kubectl apply -f velero-example-without-pv.yml
Create a backup of the namespace
# velero backup create nginx-backup --include-namespaces nginx-example
Verify that the backup is done
# velero backup describe nginx-backup
Simulate a disaster
# kubectl delete namespaces nginx-example
Restore the deleted namespace
# velero restore create --from-backup nginx-backup
Verify that the restore is correctly done
# kubectl get all -n nginx-example
In my case:
# kubectl apply -f exemples/velero/velero-example-without-pv.yml namespace/nginx-example created deployment.apps/nginx-deployment created service/my-nginx created # velero backup create nginx-backup --include-namespaces nginx-example Backup request "nginx-backup" submitted successfully. Run `velero backup describe nginx-backup` or `velero backup logs nginx-backup` for more details. # velero backup describe nginx-backup Name: nginx-backup Namespace: velero Labels: velero.io/storage-location=default [...] Started: 2019-11-05 18:11:19 +0100 CET Completed: 2019-11-05 18:11:20 +0100 CET Expiration: 2019-12-05 18:11:19 +0100 CET Persistent Volumes: <none included> # kubectl delete namespaces nginx-example namespace "nginx-example" deleted # kubectl get all -n nginx-example No resources found in nginx-example namespace. # velero restore create --from-backup nginx-backup Restore request "nginx-backup-20191105182030" submitted successfully. Run `velero restore describe nginx-backup-20191105182030` or `velero restore logs nginx-backup-20191105182030` for more details. # velero restore logs nginx-backup-20191105182030 time="2019-11-05T17:20:31Z" level=info msg="starting restore" logSource="pkg/controller/restore_controller.go:450" restore=velero/nginx-backup-20191105182030 time="2019-11-05T17:20:31Z" level=info msg="Not including resource" groupResource=events logSource="pkg/restore/restore.go:136" restore=velero/nginx-backup-20191105182030 [...] time="2019-11-05T17:20:31Z" level=info msg="Attempting to restore Service: my-nginx" logSource="pkg/restore/restore.go:1031" restore=velero/nginx-backup-20191105182030 time="2019-11-05T17:20:31Z" level=info msg="restore completed" logSource="pkg/controller/restore_controller.go:465" restore=velero/nginx-backup-20191105182030 # kubectl get all -n nginx-example NAME READY STATUS RESTARTS AGE pod/nginx-deployment-54f57cf6bf-2qhbd 1/1 Running 0 4m19s pod/nginx-deployment-54f57cf6bf-twrkm 1/1 Running 0 4m19s NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE service/my-nginx LoadBalancer 10.3.19.133 xyzxyz.lb.c1.gra.k8s.ovh.net 80:30942/TCP 4m21s NAME READY UP-TO-DATE AVAILABLE AGE deployment.apps/nginx-deployment 2/2 2 2 4m21s NAME DESIRED CURRENT READY AGE replicaset.apps/nginx-deployment-54f57cf6bf 2 2 2 4m21s
Where do we go from here
So now you have a working Velero on your cluster.
Please refer to official Velero documentation to learn how to use it, including scheduling backups, using pre-
and post-backup
hooks and other matters.
Comments
0 comments
