Learn how to back up and restore persistent volumes on an OVHcloud Managed Kubernetes cluster using Kubernetes Volume Snapshots.
Volume Snapshots are a Kubernetes feature released in General Availability (GA).
Currently, we support the following Kubernetes releases:
1.311.321.331.341.35
They provide the ability to create a “snapshot” of a persistent volume. A snapshot represents a point-in-time copy of a volume. A snapshot can be used either to rehydrate a new volume (pre-populated with the snapshot data) or to restore an existing volume to a previous state (represented by the snapshot).
Before you begin
This tutorial assumes that you already have a working OVHcloud Managed Kubernetes cluster, and some basic knowledge of how to operate it. If you want to learn more about these topics, please check out the OVHcloud Managed Kubernetes Service Quickstart.
The tutorial also assumes that you’re familiar with Kubernetes Persistent Volumes. You also need to know how PVs are handled on the OVHcloud Managed Kubernetes service. Please refer to the Persistent Volumes on OVHcloud Managed Kubernetes guide.
Setup
In this guide, we are going to use a simple example: a small Nginx web server with a PersistentVolume.
Create a file named nginx-example-with-pv.yml with the following content:
apiVersion: v1
kind: Namespace
metadata:
labels:
app: nginx
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
namespace: nginx-example
labels:
app: nginx
spec:
storageClassName: csi-cinder-high-speed
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
strategy:
type: Recreate
replicas: 1
selector:
matchLabels:
app: nginx
template:
metadata:
labels:
app: nginx
spec:
volumes:
- name: nginx-logs
persistentVolumeClaim:
claimName: nginx-logs
containers:
- image: nginx:1.7.9
ports:
- containerPort: 80
volumeMounts:
- mountPath: "/var/log/nginx"
readOnly: false
apiVersion: v1
kind: Service
metadata:
labels:
app: nginx
spec:
ports:
- port: 80
targetPort: 80
selector:
app: nginx
type: LoadBalancerNow apply it to the cluster:
kubectl apply -f nginx-example-with-pv.ymldeployment part of this manifest, you will see that we have defined a .spec.strategy.type. It specifies the strategy used to replace old pods with new ones, and we have set it to Recreate, so that all existing pods are killed before new ones are created.We do so because the Storage Class we are using,
csi-cinder-high-speed, only supports aReadWriteOnce, so we can only have one pod writing on the Persistent Volume at any given time.Wait until you get an external IP:
kubectl -n nginx-example get svc nginx-service -wWhen you have a Load Balancer external IP, save it:
export LB_IP=$(kubectl -n nginx-example get svc nginx-service -o jsonpath='{.status.loadBalancer.ingress[0].ip}')Make some calls to the URL to generate some access logs:
curl -I $LB_IPNow, we need to connect to the pod to read the log file and verify that our logs are written.
First, get the name of the Nginx-running pod:
export POD_NAME=$(kubectl get po -n nginx-example -o name)Volume snapshots work with all storage classes, including LUKS-encrypted volumes (csi-cinder-high-speed-luks, csi-cinder-classic-luks, csi-cinder-high-speed-gen2-luks). The encryption is transparently maintained during snapshot and restore operations.
Then connect to it and view your access logs:
kubectl -n nginx-example exec$POD_NAME -c nginx -- cat /var/log/nginx/access.logYou should get a result like this:
$ kubectl apply -f nginx-example-with-pv.yml
namespace/nginx-example created
persistentvolumeclaim/nginx-logs created
deployment.apps/nginx-deployment created
service/nginx-service created
$ kubectl -n nginx-example get svc nginx-service -w
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
nginx-service LoadBalancer 10.3.28.41 80:32675/TCP 4s
nginx-service LoadBalancer 10.3.28.41 80:32675/TCP 91s
nginx-service LoadBalancer 10.3.28.41 135.125.XX.XXX 80:32675/TCP 91s
nginx-service LoadBalancer 10.3.28.41 135.125.XX.XXX 80:32675/TCP 95s
$ export LB_IP=$(kubectl -n nginx-example get svc nginx-service -o jsonpath='{.status.loadBalancer.ingress[0].ip}')
$ echo $LB_IP
135.125.XX.XXX
$ curl -I $LB_IP
HTTP/1.1 200 OK
Server: nginx/1.7.9
Date: Mon, 26 Sep 2022 06:56:32 GMT
Content-Type: text/html
Content-Length: 612
Last-Modified: Tue, 23 Dec 2014 16:25:09 GMT
Connection: keep-alive
ETag: "54999765-264"
Accept-Ranges: bytes
$ curl -I $LB_IP
HTTP/1.1 200 OK
Server: nginx/1.7.9
Date: Mon, 26 Sep 2022 06:56:33 GMT
Content-Length: 612
$ export POD_NAME=$(kubectl get po -n nginx-example -o name)
$ echo $POD_NAME
pod/nginx-deployment-5bfc8c9f6f-zplsl
$ kubectl -n nginx-example exec $POD_NAME -c nginx -- cat /var/log/nginx/access.log
10.2.0.0 - - [26/Sep/2022:06:56:32 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-"
141.94.164.46 - - [26/Sep/2022:06:56:33 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-"
Creating a Snapshot
Create a VolumeSnapshot in an nginx-example-snapshot.yml file with the following content:
apiVersion: snapshot.storage.k8s.io/v1
kind: VolumeSnapshot
metadata:
spec:
volumeSnapshotClassName: csi-cinder-snapclass-in-use-v1
source:
persistentVolumeClaimName: nginx-logsNow apply it:
kubectl apply -f nginx-example-snapshot.ymlYou should get a result like this:
$ kubectl apply -f nginx-example-snapshot.yml
volumesnapshot.snapshot.storage.k8s.io/nginx-snapshot created
$ kubectl -n nginx-example get VolumeSnapshot
NAME READYTOUSE SOURCEPVC SOURCESNAPSHOTCONTENT RESTORESIZE SNAPSHOTCLASS SNAPSHOTCONTENT CREATIONTIME AGE
nginx-snapshot true nginx-logs 1Gi csi-cinder-snapclass-in-use-v1 snapcontent-131c751e-5cdb-4575-b0c0-538273c67d36 5m20s 5m20s
Simulate a disaster
Let’s simulate a disaster scenario, deleting the log files from the PVC:
kubectl -n nginx-example exec$POD_NAME -c nginx -- rm /var/log/nginx/access.log
kubectl -n nginx-example exec$POD_NAME -c nginx -- ls -al /var/log/nginx/You should get a result like this:
$ kubectl -n nginx-example exec $POD_NAME -c nginx -- rm /var/log/nginx/access.log
kubectl -n nginx-example exec $POD_NAME -c nginx -- ls -al /var/log/nginx/
total 24
drwxr-xr-x 3 root root 4096 Sep 26 07:10 .
drwxr-xr-x 1 root root 4096 Jan 27 2015 ..
-rw-r--r-- 1 root root 0 Sep 26 06:54 error.log
drwx------ 2 root root 16384 Sep 26 06:54 lost+found
Restoring the Volume
To restore from a given snapshot, you need to delete the original PVC and then recreate it from the snapshot.
Downscale the deployment to 0 replicas and delete the original PVC:
kubectl -n nginx-example scale deployment/nginx-deployment --replicas=0
kubectl -n nginx-example delete pvc nginx-logsThen, create an nginx-example-restore.yml file with the following content:
apiVersion: v1
metadata:
labels:
app: nginx
spec:
dataSource:
apiGroup: snapshot.storage.k8s.io
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1GiAnd apply it:
kubectl apply -f nginx-example-restore.ymlVerify that the PVC is restored:
kubectl -n nginx-example get pvcThe volume should have a status of Bound. Now you can restore the deployment to its replica value of 1, and wait until the pod is Running again:
kubectl -n nginx-example scale deployment/nginx-deployment --replicas=1
kubectl -n nginx-example get pods -wNow you can verify that the access.log file is back and that its content is still there:
echo $POD_NAME
kubectl -n nginx-example exec $POD_NAME -c nginx -- cat /var/log/nginx/access.logYou should get a result like this:
$ kubectl -n nginx-example scale deployment/nginx-deployment --replicas=0
deployment.apps/nginx-deployment scaled
persistentvolumeclaim "nginx-logs" deleted
$ vi nginx-example-restore.yml
$ kubectl apply -f nginx-example-restore.yml
$ kubectl -n nginx-example get pvc
NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE
nginx-logs Bound ovh-managed-kubernetes-dmhe43-pvc-d5c65ae2-e9fd-48a9-8c29-d69cdd464f59 1Gi RWO csi-cinder-high-speed 7s
$ kubectl -n nginx-example scale deployment/nginx-deployment --replicas=1
NAME READY STATUS RESTARTS AGE
nginx-deployment-5bfc8c9f6f-m627t 0/1 ContainerCreating 0 0s
nginx-deployment-5bfc8c9f6f-m627t 0/1 ContainerCreating 0 7s
nginx-deployment-5bfc8c9f6f-m627t 1/1 Running 0 10s
$ echo $POD_NAME
pod/nginx-deployment-5bfc8c9f6f-m627t
$ kubectl -n nginx-example exec $POD_NAME -c nginx -- ls -al /var/log/nginx/
total 28
drwxr-xr-x 3 root root 4096 Sep 26 06:54 .
-rw-r--r-- 1 root root 181 Sep 26 06:56 access.log
Cleanup
You can proceed to clean up by deleting everything. Delete the nginx-example namespace:
kubectl delete namespace nginx-example
For more information and tutorials, please see our other Managed Kubernetes or Platform as a Service guides. You can also explore the guides for other OVHcloud products and services.
