ETCD is one of the major components of a Kubernetes cluster. It’s a distributed key-value database that allows you to store and replicate cluster states.
At some point during the life of your Managed Kubernetes cluster, you may encounter one of the following errors which prevent you from altering resources:
rpc error: code = Unknown desc = ETCD storage quota exceeded
rpc error: code = Unknown desc = quota computation: etcdserver: not capable
rpc error: code = Unknown desc = The OVHcloud storage quota has been reached
This guide will show you how to view your usage and quota, troubleshoot, and resolve errors.
- An OVHcloud Managed Kubernetes cluster
- The kubectl command-line tool installed
Background
Each Kubernetes cluster has a dedicated quota on ETCD storage usage, calculated through the following formula:
Quota = 10MB + (25MB per node)* (capped to 200MB)
For example, a cluster with 3 b2-7
servers has a quota of 85 MB.
In order to check your current ETCD quota and usage, you can query the OVHcloud API.
Result:
"quota": 89128960,
"usage": 2604349
Note: ETCD quota and usage result are in bytes.
Using this API endpoint, you can view the ETCD usage and quota and anticipate a possible issue.
The quota can thus be increased by adding nodes, but will never be decreased (even if all nodes are removed) to prevent data loss.
The error mentioned above states that the cluster’s ETCD storage usage has exceeded the quota.
To resolve the situation, you need to delete resources created in excess.
Most common case: misconfigured cert-manager
Most users install cert-manager through Helm, and then move on a bit hastily.
The most common cases of ETCD quota issues come from a bad configuration of cert-manager, making it continuously create certificaterequest
resources.
This behavior will fill the ETCD with resources until the quota is reached.
To verify if you are in this situation, you can get the number of certificaterequest
and order.acme
resources:
kubectl get certificaterequest.cert-manager.io -A | wc -l
kubectl get order.acme.cert-manager.io -A | wc -l
If you have a huge number (hundreds or more) of those resources requests, you have found the root cause.
To resolve the situation, we propose the following method:
- Stopping cert-manager
kubectl -n <your_cert_manager_namespace> scale deployment --replicas 0 cert-manager
- Flushing all
certificaterequest
andorder.acme
resources
kubectl delete certificaterequest.cert-manager.io -A --all
kubectl delete order.acme.cert-manager.io -A --all
- Updating cert-manager
There is no generic way to do this, but if you use Helm we recommend you to use it for the update: Cert Manager official documentation
- Fixing the issue
We recommend you take the following steps to troubleshoot your cert-manager, and to ensure that everything is correctly configured: Acme troubleshoot
- Starting cert-manager
Other cases
If cert-manager is not the root cause, you should turn to the other running operators which create Kubernetes resources.
We have found that the following resources can sometimes be generated continuously by existing operators:
backups.velero.io
kubectl get backups.velero.io -A | wc -l
ingress.networking.k8s.io
kubectl get ingress.networking.k8s.io -A | wc -l
ingress.extensions
kubectl get ingress.extensions -A | wc -l
authrequests.dex.coreos.com
kubectl get authrequests.dex.coreos.com -A | wc -l
podvolumebackups
kubectl get podvolumebackups -A | wc -l
If that still does not cover your case, you can use a tool like ketall to easily list and count resources in your cluster. Then you should delete the resources in excess and fix the process responsible for their creation.
