The OVHcloud Managed Kubernetes service provides you with Kubernetes clusters without the hassle of installing or operating them.
The OVHcloud Managed Kubernetes clusters are using CoreDNS as a DNS server for Service Discovery.
At OVHcloud, we listen to our users and improve our products and services accordingly, which is why we give you the ability to customize the CoreDNS configuration, thanks to the expansion mechanism in a special Config Map which is not modified by a redeployment.
- An OVHcloud Managed Kubernetes cluster
Displaying the CoreDNS default configuration
In an OVHcloud Managed Kubernetes cluster, DNS is handled by CoreDNS.
Take a look at the ConfigMap to see the default configuration.
kubectl get configmap coredns -n kube-system -o yaml
The result should be similar to the following:
$ kubectl get configmap coredns -n kube-system -o yaml
apiVersion: v1
data:
Corefile: |
.:53 {
errors
health {
lameduck 5s
ready
kubernetes cluster.local in-addr.arpa ip6.arpa {
pods insecure
fallthrough in-addr.arpa ip6.arpa
ttl 30
prometheus :9153
forward . /etc/resolv.conf {
prefer_udp
policy sequential
cache 30
loop
reload
loadbalance
import custom/*.include
log
import custom/*.server
kind: ConfigMap
metadata:
creationTimestamp: "2022-09-22T07:00:39Z"
labels:
addonmanager.kubernetes.io/mode: EnsureExists
namespace: kube-system
resourceVersion: "5786561917"
uid: a4e7310b-50b9-4976-a014-13e4bee12344
Warning: When the Kubernetes Control Plane is redeployed or when the cluster is upgrading to the latest patch, the default CoreDNS configuration is restored.
To understand what this CoreDNS configuration means, please read the CoreDNS official documentation and CoreDNS plugins documentation.
Customizing the CoreDNS configuration
If you want to edit and customize the CoreDNS configuration, it can be done by editing the coredns-custom Config Map, which will never be altered by OVHcloud services:
$ kubectl get cm coredns-custom -n kube-system -o yaml
apiVersion: v1
data:
example.include: |
# Include .:53 example
example.server: |
# Server example
kind: ConfigMap
metadata:
creationTimestamp: "2022-10-10T09:14:03Z"
labels:
resourceVersion: "5786561924"
uid: 95c51a5d-c413-4520-b84d-a16892626620
You can add some new configuration in data.example.include and data.example.server blocks.
Edit the coredns-custom Config Map with the following command:
kubectl edit cm coredns-custom -n kube-system
For example, if you want to use a custom nameserver that will point to your private DNS, here are all the FQDN resolutions for *.myprivatedomain.com:
$ kubectl edit cm coredns-custom -n kube-system
# Please edit the object below. Lines beginning with a '#' will be ignored,
# and an empty file will abort the edit. If an error occurs while saving this file will be
# reopened with the relevant failures.
apiVersion: v1
data:
example.include: |
myprivatedomain.server: |
myprivatedomain.com.:53 {
forward . [my-custom-dns-server-private-ip]
kind: ConfigMap
metadata:
labels:
Check the logs to make sure that the customization has been applied:
kubectl logs -n kube-system -l k8s-app=kube-dns -f
Known limitations
- Full private DNS resolution is not possible - only private domains can be resolved. This means that public FQDNs are resolved by the public OVHcloud DNS. For example, when resolving
kubernetes.iofrom a Pod, the CoreDNS first resolves to.:53, which is the default nameserver. Then it resolves to the/etc/resolv.confof the underlying worker node. Then it resolves to the public OVHcloud DNS (which is configured by the OVHcloud Managed Kubernetes). - When upgrading the cluster nodes (or when a node restarts), the CoreDNS pod can be restarted and takes on the new configuration. For this reason, you need to customize the configuration through the
coredns-customConfig Map. - CoreDNS is configured to reload its configuration (Config Map here) every 30 seconds.
- New Kubernetes clusters will have the new CoreDNS Deployment & Config Maps, whereas the old ones will need to update their control plane to the latest patch.
For more information and tutorials, please see our other Managed Kubernetes support guides or explore the guides for other OVHcloud products and services.
