Learn how to use Stash to back up and restore persistent volumes on an OVHcloud Managed Kubernetes cluster.
Stash is an open-source tool to safely backup and restore, perform disaster recovery, and migrate Kubernetes persistent volumes.
We are using our Public Cloud’s Swift Object Storage with the Swift S3 API as the storage backend for Stash. Stash uses the Amazon S3® protocol to store the cluster backups on an S3™ * compatible object storage.
Before you begin
This tutorial presupposes that you already have a working OVHcloud Managed Kubernetes cluster and some basic knowledge of how to operate it. If you want to know more about those topics, please look at the OVHcloud Managed Kubernetes Service Quickstart.
You also need to have Helm installer on your workstation and your cluster, please refer to the How to Install Helm on OVHcloud Managed Kubernetes Service tutorial.
Create the Object Storage bucket for Stash
Stash needs an Object Storage bucket as a storage backend to store your cluster's data. In this section, you will create your Object Storage bucket on Swift.
Prepare your working environment
Before creating your Object Storage bucket you need to:
You should now have access to your OpenStack RC file, with a filename like <user_name>-openrc.sh, and the username and password for your OpenStack account.
Set the OpenStack environment variables
Set the environment variables by sourcing the OpenStack RC file:
source <user_name>-openrc.sh
The shell will ask you for your OpenStack password.
Create EC2 credentials
Object Storage tokens are different, you need two parameters (access and secret) to generate an Object Storage token.
These credentials will be safely stored in Keystone. To generate them with python-openstack client:
openstack ec2 credentials create
Save the access and secret parameters from the results.
Example result:
$ openstack ec2 credentials create
| Field | Value
| access | 5a4d8b8d88104123a862c527ede5a3d3
| links | {u'self': u'https://auth.cloud.ovh.us/v3/users/d74d05ff121b44bea9216495e7f0df61/credentials/OS-EC2/5a4d8b8d88104123a862c527ede5a3d3'}
| project_id | 20e124b71be141299e111ec26b1892fa
| secret | 925d5fcfcd9f436d8ffcb20548cc53a2
| trust_id | None
| user_id | d74d05ff121b44bea9216495e7f0df61
Configure awscli client
Install the awscli client:
Complete and write down the configuration for awscli into ~/aws/config:
[profile default]
aws_access_key_id = <access fetched in previous step>
aws_secret_access_key = <secret fetched in previous step>
region = <public cloud region in lower case>
endpoint_url = https://s3.<public cloud region without digit>.cloud.ovh.us
s3 =
signature_version = s3v4
addressing_style = virtual
Create an Object Storage bucket for Stash
Create a new bucket:
aws --profile default s3 mb s3://s3-stash
Create a Kubernetes Secret to store Object Storage credentials
To give Stash access to the Object Storage bucket, you need to put the credentials (the access_key and the secret_access_key) into a Kubernetes Secret.
kubectl create namespace nginx-example
echo -n '<access-key>' > AWS_ACCESS_KEY_ID
echo -n '<secret_access_key>' > AWS_SECRET_ACCESS_KEY
echo -n '<a_password>' > RESTIC_PASSWORD
kubectl create secret generic -n nginx-example s3-secret \
--from-file=./RESTIC_PASSWORD \
--from-file=./AWS_ACCESS_KEY_ID \
--from-file=./AWS_SECRET_ACCESS_KEY
Example result:
$ kubectl create namespace nginx-example
namespace/nginx-example created
$ echo -n 'xxxxxxxxxxxxxxxxxxx' > AWS_ACCESS_KEY_ID
$ echo -n 'yyyyyyyyyyyyyyyyyyy' > AWS_SECRET_ACCESS_KEY
$ echo -n 'zzzzzzzzzzzzzzzzzzz' > RESTIC_PASSWORD
$ kubectl create secret generic -n nginx-example s3-secret \
secret/s3-secret created
Install Stash
The easiest way to install Stash is via Helm, using the chart from AppsCode Charts Repository.
First of all, you need to get a license.
NOTE: If you want to use an enterprise edition, please
follow this link instead.
You should receive your license by email. Save it as you will need it in the helm install command.
Begin by adding the repository:
helm repo add appscode https://charts.appscode.com/stable/
helm repo update
Then search the latest version of stash:
helm search repo appscode/stash --version v2021.11.24
And install it with the release name stash-operator:
helm install stash appscode/stash \
--version v2021.11.24 \
--namespace kube-system \
--set features.community=true \
--set-file global.license=<PATH_TO_YOUR_STASH_LICENSE>
Example result:
$ helm repo add appscode https://charts.appscode.com/stable/
"appscode" has been added to your repositories
$ helm repo update
...Successfully got an update from the "appscode" chart repository
$ helm search repo appscode/stash --version v2021.11.24
NAME CHART VERSION APP VERSION DESCRIPTION
appscode/stash v2021.11.24 v2021.11.24 Stash by AppsCode - Backup your Kubernetes nati...
appscode/stash-catalog v2021.11.24 v2021.11.24 Stash Catalog by AppsCode - Catalog of Stash Ad...
appscode/stash-crds v2021.11.24 v2021.11.24 Stash Custom Resource Definitions
appscode/stash-metrics v2021.11.24 v2021.11.24 Stash State Metrics
$ helm install stash appscode/stash \
--set-file global.license=stash-community-license-c187ab99-64a1-4f65-9871-7e5168f48e8f.txt
W1221 14:36:32.478119 35817 warnings.go:70] policy/v1beta1 PodSecurityPolicy is deprecated in v1.21+, unavailable in v1.25+
W1221 14:36:35.308665 35817 warnings.go:70] policy/v1beta1 PodSecurityPolicy is deprecated in v1.21+, unavailable in v1.25+
W1221 14:36:35.484798 35817 warnings.go:70] policy/v1beta1 PodSecurityPolicy is deprecated in v1.21+, unavailable in v1.25+
W1221 14:36:35.526044 35817 warnings.go:70] policy/v1beta1 PodSecurityPolicy is deprecated in v1.21+, unavailable in v1.25+
W1221 14:36:35.838301 35817 warnings.go:70] spec.template.spec.nodeSelector[beta.kubernetes.io/arch]: deprecated since v1.14; use "kubernetes.io/arch" instead
W1221 14:36:35.838468 35817 warnings.go:70] spec.template.spec.nodeSelector[beta.kubernetes.io/os]: deprecated since v1.14; use "kubernetes.io/os" instead
LAST DEPLOYED: Tue Dec 21 14:36:31 2021
NAMESPACE: kube-system
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
Get the Stash operator pods by running the following command:
kubectl --namespace kube-system get pods
Verify installation
As suggested during the chart install, to check if Stash operator pods have started, we can run the suggested command and customize it to see only our stash Pod:
kubectl get pods -A -l app.kubernetes.io/name=stash-community
If everything is OK, you should get a stash-stash-community pod with a status Running.
NAMESPACE NAME READY STATUS RESTARTS AGE
kube-system stash-stash-community-84b7f84b7f-ctzv7 2/2 Running 0 35s
Now, to confirm CRD groups have been registered by the operator, run the following command:
kubectl get crd | grep stash
Example result:
$ kubectl get crd | grep stash
backupblueprints.stash.appscode.com 2021-12-21T13:36:47Z
backupconfigurations.stash.appscode.com 2021-12-21T13:36:46Z
backupsessions.stash.appscode.com 2021-12-21T13:36:46Z
functions.stash.appscode.com 2021-12-21T13:24:18Z
recoveries.stash.appscode.com 2021-12-21T13:36:46Z
repositories.stash.appscode.com 2021-12-21T13:36:46Z
restics.stash.appscode.com 2021-12-21T13:36:46Z
restorebatches.stash.appscode.com 2021-12-21T13:36:48Z
restoresessions.stash.appscode.com 2021-12-21T13:36:47Z
tasks.stash.appscode.com 2021-12-21T13:24:18Z
Install Stash kubectl plugin
Stash provides a CLI using kubectl plugin to work with the stash Objects quickly. Download pre-built binaries from stashed/cli Github release and put the binary to some directory in your PATH.
Volume Snapshot with Stash
A detailed explanation of Volume Snapshot with Stash is available in the official documentation.
In Kubernetes, a Volume Snapshot represents a snapshot of a volume on a storage system. It was introduced as an Alpha feature in Kubernetes v1.12 and has been promoted to a Beta feature in Kubernetes 1.17.
In order to support VolumeSnapshot, your PersistentVolumes need to use a StorageClass with a CSI driver that supports the feature. Currently, OVHcloud Managed Kubernetes cluster propose you two of these: StorageClasses, csi-cinder-classic, and csi-cinder-high-speed.
You also need a compatible VolumeSnapshotClass - in our case, csi-cinder-snapclass.
An example: Nginx server with persistent logs
For this example, we will use a small Nginx web server with a PersistentVolume to store the access logs.
Copy the following description to a nginx-example.yml file:
apiVersion: v1
kind: Namespace
metadata:
labels:
app: nginx
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
namespace: nginx-example
labels:
app: nginx
spec:
storageClassName: csi-cinder-high-speed
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 50Mi
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
strategy:
type: Recreate
replicas: 1
selector:
matchLabels:
app: nginx
template:
metadata:
labels:
app: nginx
spec:
volumes:
- name: nginx-logs
persistentVolumeClaim:
claimName: nginx-logs
containers:
- image: nginx:1.7.9
ports:
- containerPort: 80
volumeMounts:
- mountPath: "/var/log/nginx"
readOnly: false
apiVersion: v1
kind: Service
metadata:
labels:
app: nginx
spec:
ports:
- port: 80
targetPort: 80
selector:
app: nginx
type: LoadBalancer
And apply it to your cluster:
kubectl apply -f nginx-example.yml
If you look attentively to the deployment part of this manifest, you will see that we have defined a .spec.strategy.type. It specifies the strategy used to replace old Pods by new ones, and we have set it to Recreate, so all existing Pods are killed before new ones are created.
We do so as the Storage Class we are using, csi-cinder-high-speed, only supports a ReadWriteOnce, so we can only have one pod writing on the Persistent Volume at any given time.
We can check if the Pod is running:
kubectl get pod -n nginx-example
Wait until you get an external IP:
kubectl -n nginx-example get svc nginx-service -w
And do some calls to the URL to generate some access logs:
Example results:
$ kubectl apply -f nginx-example.yml
persistentvolumeclaim/nginx-logs created
deployment.apps/nginx-deployment created
service/nginx-service created
$ kubectl get pod -n nginx-example
nginx-deployment-766444c4d9-cxd2p 1/1 Running 0 32s
$ kubectl -n nginx-example get svc nginx-service -w
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
nginx-service LoadBalancer 10.3.39.164 <pending> 80:31734/TCP 49s
nginx-service LoadBalancer 10.3.39.164 51.210.210.247 80:31734/TCP 3m
$ curl -I 51.210.210.247
HTTP/1.1 200 OK
Server: nginx/1.7.9
Date: Tue, 21 Dec 2021 14:16:20 GMT
Content-Type: text/html
Content-Length: 612
Last-Modified: Tue, 23 Dec 2014 16:25:09 GMT
Connection: keep-alive
ETag: "54999765-264"
Accept-Ranges: bytes
HTTP/1.1 200 OK
Server: nginx/1.7.9
Date: Tue, 21 Dec 2021 14:16:31 GMT
Content-Length: 612
Verify the logs
Now we need to connect to the pod to read the log file and verify that our logs are written.
First, get the name of the Nginx running pod:
kubectl -n nginx-example get pods
And then connect to it and see your access logs:
kubectl -n nginx-example exec <POD_NAME> -c nginx -- cat /var/log/nginx/access.log
Example results:
$ kubectl -n nginx-example get pods
nginx-deployment-766444c4d9-cxd2p 1/1 Running 0 28m
$ kubectl -n nginx-example exec nginx-deployment-766444c4d9-cxd2p -c nginx -- cat /var/log/nginx/access.log
10.2.2.0 - - [21/Dec/2021:14:16:20 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-"
10.2.0.0 - - [21/Dec/2021:14:16:31 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-"
Create a Repository
A Repository is a Kubernetes CustomResourceDefinition (CRD) which represents backend information in a Kubernetes native way. You have to create a Repository object for each backup target. A backup target can be a workload, database or a PV/PVC.
To create a Repository CRD, you have to provide the storage secret that we have created earlier in spec.backend.storageSecretName field. You will also need to define spec.backend.s3.prefix, to choose the folder inside the backend where the backed up snapshots will be stored.
Create a repository.yaml file, replacing <public cloud region> with the region, without digits and in lowercase (e.g., us-east-va-1):
apiVersion: stash.appscode.com/v1alpha1
kind: Repository
metadata:
spec:
backend:
s3:
endpoint: s3.<public cloud region>.cloud.ovh.us
bucket: s3-stash
region: <public cloud region>
prefix: /backup/nginx-demo
storageSecretName: s3-secret
And apply it to your Kubernetes cluster:
kubectl apply -f repository.yml
Example result:
$ kubectl apply -f repository.yaml
repository.stash.appscode.com/s3-repo created
Create a BackupConfiguration
A BackupConfiguration is a Kubernetes CustomResourceDefinition (CRD) which specifies the backup target, parameters (schedule, retention policy, etc.), and a Repository object that holds snapshot storage information in a Kubernetes-native way.
You have to create a BackupConfiguration object for each backup target. A backup target can be a workload, database, or a PV/PVC.
To back up our PV we will need to create a backup-configuration.yaml file, where we describe the Persistent Volumes we want to back up, the repository we intend to use and the backing up schedule (in crontab format):
apiVersion: stash.appscode.com/v1beta1
kind: BackupConfiguration
metadata:
spec:
repository:
schedule: "*/5 * * * *"
target:
ref:
apiVersion: apps/v1
kind: Deployment
volumeMounts:
- name: nginx-logs
mountPath: /var/log/nginx
paths:
- /var/log/nginx
retentionPolicy:
keepLast: 5
prune: true
kubectl apply -f backup-configuration.yml
Example result:
$ kubectl apply -f backup-configuration.yaml
backupconfiguration.stash.appscode.com/nginx-backup created
Verify CronJob
If everything goes well, Stash will create a CronJob to take periodic snapshot of nginx-logs volume of the deployment with the schedule specified in spec.schedule field of BackupConfiguration CRD (a backup every five minutes).
Check that the CronJob has been created:
kubectl -n nginx-example get cronjob
Example result:
$ kubectl -n nginx-example get cronjob
NAME SCHEDULE SUSPEND ACTIVE LAST SCHEDULE AGE
stash-backup-nginx-backup */5 * * * * False 0 33s 3m36s
Wait for BackupSession
The stash-backup-nginx-backup CronJob will trigger a backup on each schedule by creating a BackupSession CRD.
Wait for the next backup schedule. Run the following command to watch BackupSession CRD:
kubectl -n nginx-example get backupsession
Example result:
$ kubectl -n nginx-example get backupsessions
NAME INVOKER-TYPE INVOKER-NAME PHASE AGE
nginx-backup-1586938564 BackupConfiguration nginx-backup Succeeded 77s
We can see above that the backup session has succeeded. Now, we are going to verify that the VolumeSnapshot has been created and the snapshots has been stored in the respective backend.
Verifying Volume Snapshots in OVHcloud Cloud Manager
The snapshots are visible in the OVHcloud Control Panel. To see them, go to Object Storage section, where you will find the Object Storage bucket you have created. By clicking on the bucket you will see the list of objects, including all the snapshots beginning with the /backup/demo/deployment/stash-demo we had defined in the Repository:
Restore PVC from VolumeSnapshot
This section will show you how to restore the PVCs from the snapshots we have taken in the previous section.
Stop Snapshotting
Before restoring we need to pause the BackupConfiguration to prevent any snapshotting during the restore process. With the BackupConfiguration, Stash will stop taking any further backups for nginx-deployment.
kubectl -n nginx-example patch backupconfiguration nginx-backup --type="merge" --patch='{"spec": {"paused": true}}'
After some moments, you can look at the nginx-backup status to see it paused:
kubectl -n nginx-example get backupconfiguration nginx-backup
Example results:
$ kubectl -n nginx-example patch backupconfiguration nginx-backup --type=
backupconfiguration.stash.appscode.com/nginx-backup patched
$ kubectl -n nginx-example get backupconfiguration nginx-backup
NAME TASK SCHEDULE PAUSED AGE
nginx-backup */1 * * * * true 7m18s
Simulate Disaster
Let’s simulate a disaster scenario, deleting all the files from the PVC:
kubectl -n nginx-example exec <POD_NAME> -c nginx -- rm /var/log/nginx/access.log
And verify that the file is deleted:
kubectl -n nginx-example exec <POD_NAME> -c nginx -- ls -al /var/log/nginx/
Example results:
$ kubectl -n nginx-example -c nginx exec nginx-deployment-766444c4d9-cxd2p -- rm /var/log/nginx/access.log
$ kubectl -n nginx-example exec nginx-deployment-766444c4d9-cxd2p -c nginx -- ls -al /var/log/nginx/
total 32
drwxr-xr-x 3 root root 4096 Dec 21 13:42 .
drwxr-xr-x 1 root root 4096 Jan 27 2015 ..
-rw-r--r-- 1 root root 1369 Dec 21 14:15 error.log
drwx------ 2 root root 16384 Dec 21 13:42 lost+found
Create a RestoreSession
Now you need to create a RestoreSession CRD to restore the PVCs from the last snapshot.
A RestoreSession is a Kubernetes CustomResourceDefinition (CRD) which specifies a target to restore and the source of data that will be restored in a Kubernetes native way.
Create a restore-session.yaml file:
kind: RestoreSession
metadata:
spec:
repository:
target:
ref:
apiVersion: apps/v1
kind: Deployment
volumeMounts:
- name: nginx-logs
kubectl apply -f restore-session.yaml
And wait for the RestoreSession to succeed:
kubectl -n nginx-example get restoresession nginx-restore
Example results:
$ kubectl apply -f ./examples/stash/restore-session.yaml
restoresession.stash.appscode.com/nginx-restore created
$ kubectl get restoresession -n nginx-example nginx-restore -w
NAME REPOSITORY PHASE AGE
nginx-restore s3-repo Succeeded 50s
Verify the data is restored
Let's begin by getting the pod name:
And then verify that the access.log file has been restored:
Example results:
nginx-deployment-766444c4d9-cxd2p 2/2 Running 0 31s
total 32
-rw-r--r-- 1 root root 1686 Dec 21 15:03 access.log
-rw-r--r-- 1 root root 1369 Dec 21 14:55 error.log
drwx------ 2 root root 16384 Dec 21 14:55 lost+found
Cleaning up
To clean up your cluster, begin by deleting the nginx-example namespace:
kubectl delete namespace nginx-example
Then simply use Helm to delete your Stash release.
helm uninstall stash -n kube-system
Example results:
$ kubectl delete namespace nginx-example
namespace "nginx-example" deleted
$ helm uninstall stash -n kube-system
release "stash" uninstalled
For more information and tutorials, please see our other Managed Kubernetes or Platform as a Service guides. You can also explore the guides for other OVHcloud products and services.
*S3 is a trademark filed by Amazon Technologies, Inc. OVHcloud's service is not sponsored by, endorsed by, or otherwise affiliated with Amazon Technologies, Inc.
