The OVHcloud Control Panel enables you to create backups of your instances within a few clicks, as well as automating this process. You can make use of these instance backups for two basic purposes:
- Creating a new instance with the backup as a template in order to duplicate the original instance, for example if you are configuring a load balancing infrastructure.
- Restoring instances from a backup, for example if recent changes broke critical configurations on the instance.
This guide explains how to use backups to duplicate and restore your instances.
- A backup of a Public Cloud instance
Creating an instance from a backup
Log in to the OVHcloud Control Panel and open your Public Cloud
project. Click on Instance Backup
in the left-hand sidebar.
Click on the ...
button in the row of the relevant backup, then select Create an instance
You will see a shortened version of the instance creation page where you can decide on some options.
Some elements are pre-defined:
- Region: Your instance will be created in the same data centre as your backup.
- Image: The image will correspond to your backup.
- Model: Only the models that are compatible with your image are available, depending on your quota.
Choose the new instance’s name, SSH key, vRack and billing period, then click on the Create the instance
button.
For further information on creating an instance, please refer to this guide.
Restoring an instance from a backup
Log in to the OVHcloud Control Panel and switch to the Public Cloud
section. Click on Instances
Click on the ...
button in the row of the relevant instance, then select Edit
This opens the page for editing an instance where you can change:
- the instance’s name
- the instance’s image
- the instance’s model
- the instance’s billing mode (from
hourly
tomonthly
only)
Make your changes if necessary and switch to the Backups
tab of the Image section.
Select from the list of available backups. Click on Modify image
if you are certain that you want to overwrite the current image with the backup.
The instance will have the status Re-installation
until the process is completed. It might be necessary to refresh the page in the browser in order to see the current status.
Comments
0 comments
