Owncloud is a suite of client-server software for creating and using file hosting services.
This guide explains how to set up storage in Owncloud to use a S3 Object Storage container.
- A container
- A user with the required access rights on the container
- Your S3 credentials (access_key and secret_access_key)
See our Getting Started with S3 Object Storage guide.
If needed, install the External Storage: S3
plugin from the Market
Search for the External Storage: S3
plugin.
And install
it.
Go to the Settings
Then :
- in
Storage
- enable
Enable external storage
- name your folder
- add an
Amazon S3 compatible storage (SDK v3)
Fill in the following information:
- Enter the name of your container
- Set the host as:
s3.<region_in_lowercase>.io.cloud.ovh.us
- Set the port to 443
- Specify the region
- Activate SSL
- Enter your access key
- Enter your secret key
Go toFiles
Then navigate to External storage
The result should be similar to this:
