Learn how to configure a block of public IP addresses for use with the vRack.
As well as private IP addressing, the vRack also allows you to route public IP traffic through your server’s vRack port using a public IP address block.
- a public block of IP addresses in your account, with a minimum of four addresses
- your chosen private IP address range
- a vRack-compatible server
- a vRack service activated in your account
- access to the OVHcloud Manager
For example purposes, the network configuration file we refer to is located in /etc/network/interfaces. The equivalent file on your server may be located somewhere else, depending on your operating system. The file content may also be different. If you encounter any difficulties, please refer to the official documentation for your distribution.
Add the IP block to the vRack
This setup allows you to configure IPs of the same block on multiple servers, provided that these servers are all in the same vRack as the IP block. The IP block must have at least 2 usable IPs or more for this to be possible.
In your OVHcloud Control Panel, go to the Bare Metal Cloud
section and click on Network
. Next, open the vRack
menu.
Select your vRack from the list to display the list of eligible services. Click the IP block you wish to add to the vRack and click on the Add
button.
Configure a usable IP address
For vRack purposes, the first, penultimate, and last addresses in any given IP block are always reserved for the network address, network gateway, and network broadcast respectively. This means that the first useable address is the second address in the block, as shown below:
46.105.135.96 Reserved: Network address
46.105.135.97 First usable IP
46.105.135.98
46.105.135.99
46.105.135.100
46.105.135.101
46.105.135.102
46.105.135.103
46.105.135.104
46.105.135.105
46.105.135.106
46.105.135.107
46.105.135.108
46.105.135.109 Last usable IP
46.105.135.110 Reserved: Network gateway
46.105.135.111 Reserved: Network broadcast
To configure the first usable IP address, we need to edit the network configuration file, as shown below. In this example, we need to use a subnet mask of 255.255.255.240.
auto eth1
iface eth1 inet static
address 46.105.135.97
netmask 255.255.255.240
broadcast 46.105.135.111
Create a new IP routing table
First, we need to download and install iproute2, which is a package that will enable us to manually configure IP routing on the server.
Establish an SSH connection to your server and run the following command from the command line. This will download and install iproute2.
# apt install iproute2
Next, we need to create a new IP route for the vRack. We will be adding a new traffic rule by amending the file, as shown below:
/etc/iproute2/rt_tables
# reserved values
255 local
254 main
253 default
0 unspec
# local
#1 inr.ruhep
1 vrack
Amend the network configuration file
Finally, we need to amend the network configuration file to account for the new traffic rule and route the vRack traffic through the network gateway address of 46.105.135.110.
auto eth1
post-up ip route add 46.105.135.96/28 dev eth1 table vrack
post-up ip route add default via 46.105.135.110 dev eth1 table vrack
post-up ip rule add from 46.105.135.96/28 table vrack
post-up ip rule add to 46.105.135.96/28 table vrack
Now reboot your server to apply the changes.
For more information and tutorials, please see our other Server Administration support guides or explore the guides for other OVHcloud products and services.
