Learn how to deploy the Speech to Text Application created in this blog article using Streamlit and pre-trained models.
Deploying your app will allow you to benefit from very powerful resources, which will make the speech-to-text application extremely fast. It can also be easily shared, unlike a local application.
Here, the use case is English Speech Recognition, but you can choose another model as explained in our blog article. Some models work with Chinese, French, German, Japanese, Russian, etc.
AI Deploy is covered by OVHcloud Public Cloud Special Conditions.
Overview of the Speech-to-Text app:
To deploy your app, you need:
- An AI Deploy Project created inside a Public Cloud project in your OVHcloud account
- A user for AI Deploy
- The OVHcloud AI CLI and Docker installed on your local computer, or only access to a Debian Docker Instance on the Public Cloud
- To deploy your app, you must have the full code of the application, either by cloning the GitHub repository or by following our blog article that taught you how to build this app step by step
- If you want the diarization option (speaker differentiation), you will need an access token. This token will be requested at the launch of the application. To create your token, follow the steps indicated on the model page. If the token is not specified, the application will be launched without this feature.
You are going to follow different steps to deploy your Streamlit Speech to Text application:
- Write & Install the libraries and packages in our environment so that our application can work.
Write the
Dockerfile
that contains all the commands to launch our speech-to-text app. - Build the Docker image from the Dockerfile
- (Optional) - Import the models and save them locally in an Object Storage (volume) to speed up the initialization of the app.
- Deploy your app.
If you have cloned the GitHub repository, you will not need to rewrite the files (requirements.txt and Dockerfile) since you already have them. In this case, you can go directly to the "Build the Docker image" step, even if it is better to understand the global operation.
Write the requirements.txt file for the application
The requirements.txt
file will allow us to write all the modules needed by our application. This file will be useful for the Dockerfile
. Put this file (and the next ones) in the same directory as your Python scripts.
A Dockerfile
is a text document that contains all the commands a user could call on the command line to build an image.
This file should start with the FROM
instruction, indicating the parent image to use. In our case, we choose to start from the official python:3.8
image:
We recommend that you do not downgrade the version of Python. Indeed, according to pyannote.audio's documentation, only python 3.8+ is officially supported for the moment.
Then, define the home directory and add all your files (python scripts, requirements.txt, and the Dockerfile) to it thanks to the following commands:
With AI Deploy, workspace
will be your home directory.
We can now install our needed system packages. To do this, use apt-get
, which is a command-line tool that helps in handling packages:
Use a pip install ...
command to install our needed python modules that are in the requirements.txt
file:
Once your environment is set up, define your default launching command to start the application:
Finally, create a data
folder which will temporarily store users' audio files until they are transcribed. Then, give the correct access rights to the OVHcloud user (42420:42420
The first command builds the image using your system’s default architecture. This may work if your machine already uses the
linux/amd64
architecture, which is required to run containers with our AI products. However, on systems with a different architecture (e.g.ARM64
onApple Silicon
), the resulting image will not be compatible and cannot be deployed. -
The second command explicitly targets the
linux/AMD64
architecture to ensure compatibility with our AI services. This requiresbuildx
, which is not installed by default. If you haven’t usedbuildx
before, you can install it by running:docker buildx install
The dot argument .
indicates that your build context (place of the Dockerfile and other needed files) is the current directory.
The -t
argument allows you to choose the identifier to give to your image. Usually, image identifiers are composed of a name and a version tag <name>:<version>
. For this example, we chose streamlit_app:latest.
NOTE: The shared registry should only be used for testing purposes. Please consider creating and attaching your own registry. More information about this can be found here. The images pushed to this registry are for AI Tools workloads only and will not be accessible for external uses.
Log in on your shared registry with your usual AI Platform user credentials:
Tag the compiled image and push it into your shared registry:
Import the models and save them locally (Optional)
As we explained in the blog article, you will considerably reduce the initialization time of the app if you download the models and store them in a local folder. This will allow you not to have to download them again every time you relaunch the application.
To do this, we will use AI Training. This will allow us to launch a Python script from GitHub that will download the models and store them in an OVHcloud volume named speech_to_text_app_models
. When the models will be downloaded and added to this volume, the status of the job will automatically switch from Running
to Done
and the job will be immediately stopped. This operation should be quite fast.
Unfortunately, the diarization model can't be saved anymore since pyannote.audio v2. The application will load it in the classical way, by using your model access token, which will be requested by the application once launched.
To launch this AI Training job and download the models, use the following OVHcloud's CLI command:
corresponds to the name of your Docker image.
--volume
allows you to specify what volume you want to add to your job. As mentioned, we add the volume speech_to_text_app_models
and we put it in RW
(read and write) mode since we want to add our models to this volume. If you do not have this volume in your Object Storage list, do not worry, it will be created automatically. As you can see, the --volume
parameter also allows you to get files from a GitHub repository, which in our case contains the script to download the models.
--bash
allows you to provide commands through which you install the libraries mentioned in your requirements.txt
file, and run the Python script.
When you run this command, an Info url
will appear. Opening it will allow you to track the status of the job. Once the GitHub repository is recovered, the Python script will be launched and the job status will switch to Running
. Then, you just have to wait for the job to end.
We advise you to turn on the auto-refresh option (Running
status automatically disables it). This will allow you to see when the job will end (job status switches to Done
). Otherwise, you can refresh the page manually.
Once the models have been uploaded and the status is Done
, you can continue.
Launch the app on AI Deploy
If you followed the optional part Import the models and save them locally
, you can load the volume where your models are stored with the --volume
parameter. This time, we put this volume in read-only (RO
) mode because we only need to have access to the models so we can use them. We don't need to write or delete anything in this Object Storage container.
Otherwise, you can remove the --volume
line, since it will not bring anything to your app.
The following command starts a new app running your Streamlit application:
default-http-port 8501
indicates that the port to reach on the app URL is the 8501
--cpu 6
indicates that we request 6 CPUs for our app. If you would like to deploy with GPUs, certain changes will need to be made in your app.py
file to ensure driver compatibility.
If you want your app to be accessible without the need to authenticate, specify it as follows:
Consider adding the --unsecure-http
attribute if you want your application to be reachable without any authentication.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
