This tutorial covers the process of starting a job using Visual Studio Code Remote via SSH.
- an AI Training project created inside a Public Cloud project
- a user for AI Training
- installing the OVHcloud AI CLI
NOTE: The deployed image needs to contain the bash
binary and a glibc-based Linux (Ubuntu / Debian).
Installation
- Install an OpenSSH-compatible SSH client if one is not already present.
- Install Visual Studio Code.
- Install the Remote Development extension pack.
Start a job with the SSH feature
We will launch a job with the CLI, just choose the number of GPUs (<nb-gpus>
) to use on your job and use the following command:
Once the job is Running
, you can see the sshUrl
with job get:
Configure VSCode Remote Development
Verify you can connect to the SSH host by running the following command from a terminal / PowerShell window replacing user\@hostname accordingly:
Click on the Remote Explorer Button.
Then click on the +
button to add an SSH server.
Then click on the window icon near your server in the list.
Enjoy.
- You can compare AI models based on resource consumption, accuracy, and training time. Refer to this tutorial.
For more information and tutorials, please see our other AI & Machine Learning support guides or explore the guides for other OVHcloud products and services.
