Learn how to manage OpenStack users in the OVHcloud Control Panel.
Access to Horizon and the OpenStack APIs is established via username/password pairs called "OpenStack users". You can create as many OpenStack users as needed and assign them various access permissions.
- A Public Cloud project in your OVHcloud account
You may request to remove this security measure by creating a support ticket in the OVHcloud Control Panel.
Creating an OpenStack user
Log in to the OVHcloud Control Panel and open your Public Cloud
project. Click on Users & Roles
in the left-hand menu under Project Management.
Click on the button Create User
The user description is not the username for the OpenStack user but a descriptive term to help you organize users and their permissions. Enter a description and click on Next
Now you can select user roles representing the permissions the user shall have.
For each box checked, the user will gain access privileges according to the table below.
Click on Confirm
to create the OpenStack user. The username and password will be automatically generated and displayed in your Control Panel.
Be sure to save the password shown in the green message box to a password manager at this time. The password cannot be recovered afterward. However, you can always create a new password by clicking on the more options ...
button and selecting Generate a password
You can also edit the roles of a user at any time by clicking the more options ...
button and selecting Edit roles
. The Show role matrix
button will display the access privileges of each role.
With the OpenStack user created, you can use its credentials to log into the Horizon interface by clicking on the link Horizon
in the left-hand menu.
Deleting an OpenStack user
You can remove an OpenStack user in the OVHcloud Control Panel. After clicking Public Cloud
from the top navigation menu, click on Users & Roles
Click on the more options ...
button in the user's row and select Delete
For more information and tutorials, please see our other guides on Instance Management, Public Cloud, or other OVHcloud products and services.
