Cloud Databases and Analytics
With our Cloud Databases and Analytics services, we manage the infrastructure and administration, including set-up, backup, scalability, and security. Choose from a large portfolio of popular engines.
We continuously improve our offers. You can follow and submit ideas to add to our roadmap.
Databases for...
Caching is an open-source fully managed in-memory NoSQL database based on the Redis® open-source software. It helps you store and access data quickly and efficiently.
See our Caching Capabilities and Limitations guide.
Apache Cassandra is an open-source fully managed NoSQL database. It's highly fault-tolerant with asynchronous replication.
See our Cassandra Capabilities and Limitations guide.
MongoDB is a fully managed and scalable document-oriented database management system that does not require a predefined data schema.
See our MongoDB Capabilities and Limitations guide.
MySQL is an open-source fully-managed relational database service. It's fast, reliable, scalable, and user-friendly.
See our MySQL Capabilities and Limitations guide.
PostgreSQL is an open-source fully managed and hosted relational database service. It's a high-performance engine that offers flexibility through a variety of included advanced extensions.
See our PostgreSQL Capabilities and Limitations guide.
Analytics with...
Grafana® is not a database; it is a monitoring and analysis solution commonly used to visualize and analyze data from various sources, including databases.1
See our Grafana® Capabilities and Limitations guide.
Kafka is a high-performance distributed streaming system designed for durability, scalability, and real-time data streaming across multiple applications and platforms.
See our Kafka Capabilities and Limitations guide.
Kafka Connect is a Kafka extension to facilitate connection to your external data systems.
See our Kafka Connect Capabilities and Limitations guide.
Kafka MirrorMaker is a data replication system between two Kafka clusters.
See our Kafka MirrorMaker Capabilities and Limitations guide.
OpenSearch is an open-source fully managed search, analytics, and observability engine. It is ideal for logs management and offers search and analytical aggregations.
OpenSearch is an open-source fork derived from Elasticsearch.
See our OpenSearch Capabilities and Limitations guide.
Feature Availability
Feature | Caching | Cassandra | Grafana | Kafka | Kafka Connect | Kafka MirrorMaker | MongoDB | MySQL | OpenSearch | PostgreSQL |
End-to-end security (more information) | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
Automatic updates and one-click upgrade | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
Read-only nodes | ❌ | ❌ | ❌ | ❌ | ❌ | ❌ | ✅ | ✅ | ❌ | ✅ |
Point-in-Time Recovery | ❌ | ❌ | ❌ | ❌ | ❌ | ❌ | ✅ [*] | ✅ | ❌ | ✅ |
Database forking | ✅ | ❌ | ✅ | ❌ | ❌ | ❌ | ✅ | ✅ | ✅ | ✅ |
Terraform Provider support (more information) | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
Private network connectivity (vRack) | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
[*]: Depends on the plan.
Specific feature Plans
NOTE: The MongoDB engine has different plan names. See this guide for more information about MongoDB plans.
Essential
The Essential plan typically offers the basic features and functionalities required for managing an engine. It is designed for test and development environments or non-critical projects.
Business
The Business plan is more comprehensive and suitable for organizations with higher engine demands. This is the first production-ready offering.
Enterprise
The enterprise pricing plan is the most advanced and robust option available for managed engines. It is dedicated to organizations with complex and high-performance engine requirements.
Plan capabilities overview
Here is an overview of the various plans' capabilities:
Feature | Essential | Business | Enterprise |
SLA | None | 99.9% | 99.95% |
High Availability | ✓ | ✓ |
Your choice of plan affects the number of nodes your cluster can run.
[1]: The Grafana Labs Marks are trademarks of Grafana Labs, and are used with Grafana Labs’ permission. We are not affiliated with, endorsed or sponsored by Grafana Labs or its affiliates.
