In this tutorial we are going to guide you with the install of a Functions as a Service (FaaS) platform on OVHcloud Managed Kubernetes service.
The question of how to install a FaaS platform on OVH comes recurrently, and in this tutorial you will get some answers with a quick and painless solution: install the FaaS platform over OVHcloud Managed Kubernetes.
That’s the beauty of the rich Kubernetes ecosystem, you can find projects to address many different use case, from the game server with Agones to a FaaS platform…
We have tested several FaaS platform on OVHcloud Managed Kubernetes. Our objective was a solution:
- Easy to deploy, ideally a simple Helm chart
- Manageable with both an UI and a CLI, because different customers have different needs
- Auto-scalable, both is ascending and descending senses
- With a comprehensive documentation
We tested lots of platforms, like Kubeless, OpenWhisk, OpenFaaS and Fission, and I must said that all of them performed quite well.
At the end, the one that scored the best on our objectives was OpenFaaS, so we decided to use it as reference for this tutorial.
Before you begin
This tutorial presupposes that you already have a working OVHcloud Managed Kubernetes cluster, and some basic knowledge of how to operate it. If you want to know more on those topics, please look at the deploying a Hello World application documentation.
You also need to have Helm installed on your workstation and your cluster, please refer to the How to install Helm on OVHcloud Managed Kubernetes Service tutorial.
OpenFaaS, a Kubernetes-native FaaS platform
OpenFaaS is an open source framework for building Serverless functions with Docker and Kubernetes. The project is mature, very popular and active with more than 14k stars on GitHub, a hundred of contributors, and lots of users, both corporate and private.
OpenFaaS is very simple to deploy (with an Helm chart,including an Operator allowing use of CRDs i.e. kubectl get functions
), it has both a CLI and an UI, it manages well the auto-scaling and its doc is really complete (with in bonus a nice Slack channel to discuss about it!).
Technically, OpenFaaS is composed of several functional blocks:
The Function Watchdog, a tiny golang HTTP server that transforms any Docker image into a serverless function
The API Gateway, providing an external route into functions and collecting metrics
The UI Portal, allowing to create and invoke functions
The CLI (essentially a REST client for the API Gateway), used to deploy any container as a function
Functions can be written on many languages (I have mainly tested on JavaScript, Go and Python), using handy templates or simple a Dockerfile.
Deploying OpenFaaS on OVHcloud Managed Kubernetes
There are several ways to install Agones in a Kubernetes cluster. In this post we choose the easiest one: installing with Helm.
The official Helm chart for OpenFaas is available on faas-netes repository.
Adding the OpenFaaS helm chart
The OpenFaaS Helm chart isn’t available in Helm’s standard stable
repository. You need to add their repository to your Helm install:
# helm repo add openfaas https://openfaas.github.io/faas-netes/
# helm repo update
Creating the namespaces
OpenFaaS guidelines advise to create two namespaces, one for OpenFaaS core services and one for the functions:
# kubectl apply -f https://raw.githubusercontent.com/openfaas/faas-netes/master/namespaces.yml
Generating secrets
A FaaS platform open to the internet seems a bad idea. We are generating secrets to enable authentication on the gateway.
# generate a random password
PASSWORD=$(head -c 12 /dev/urandom | shasum| cut -d' ' -f1)
# kubectl -n openfaas create secret generic basic-auth \
--from-literal=basic-auth-user=admin \
--from-literal=basic-auth-password="$PASSWORD"
You will need this password later on the tutorial, for example to access the UI portal. You can see it at any moment in the terminal session by doing echo $PASSWORD
Deploying the Helm chart
The Helm chart can be deployed in three modes: LoadBalancer
, NodePort
and Ingress
. For us the simplest way is simply using our external Load Balancer, so we will deploy it in LoadBalancer
by setting the --set serviceType=LoadBalancer
option.
If you want to better understand the difference between these three modes, you can read our Getting external traffic into Kubernetes – ClusterIp, NodePort, LoadBalancer, and Ingress blog post
Deploy the Helm chart:
# helm upgrade openfaas --install openfaas/openfaas \
--namespace openfaas \
--set basic_auth=true \
--set functionNamespace=openfaas-fn \
As suggested in the install message, you can verify that OpenFaaS has started by running:
# kubectl --namespace=openfaas get deployments -l "release=openfaas, app=openfaas"
If it’s working you should see the list of OpenFaaS deployment
objects, marked as available:
NAME DESIRED CURRENT UP-TO-DATE AVAILABLE AGE
alertmanager 1 1 1 1 33s
faas-idler 1 1 1 1 33s
gateway 1 1 1 1 33s
nats 1 1 1 1 33s
prometheus 1 1 1 1 33s
queue-worker 1 1 1 1 33s
Install the FaaS CLI and log into the API Gateway
The easiest way to interact with your new OpenFaaS platform is intalling faas-cli
, the command line client for OpenFaaS (on a Linux or Mac, or in a WSL linux terminal in Windows):
# curl -sL https://cli.openfaas.com | sh
You can now use the CLI to log into the gateway. The CLI need the public URL of the OpenFaaS LoadBalancer
, you can get it via kubectl
# kubectl get svc -n openfaas gateway-external -o wide
At this moment you can get an EXTERNAL-IP <none>
, or EXTERNAL-IP <PENDING>
# kubectl get svc -n openfaas gateway-external -o wide NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
gateway-external LoadBalancer 10.3.xxx.yyy PENDING 8080:30012/TCP 10s
The problem come from the the LoadBalancer
creation, that is asynchronous, and the provisioning of the load balancer can take several minutes. Please try again in a few minutes, and you will normally see the newly assigned URL.
Export the URL to a OPENFAAS_URL
variable
# export OPENFAAS_URL=[THE_URL_OF_YOUR_LOADBALANCER]:[THE_EXTERNAL_PORT]
You will need this URL later on the tutorial, for example to access the UI portal. You can see it at any moment in the terminal session by doing echo $OPENFAAS_URL
And connect to the gateway:
# echo -n $PASSWORD | ./faas-cli login -g $OPENFAAS_URL -u admin --password-stdin
Now you’re connected to the gateway, and you can send commands to the OpenFaaS platform.
By default, there is no function installed on your OpenFaaS platform, as you can verify with the faas-cli list
command.
In my own deployment (URLs and IP changed), the precedent operations gave:
# kubectl get svc -n openfaas gateway-external -o wide NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE SELECTOR gateway-external LoadBalancer 10.3.xxx.yyy xxxrt657xx.lb.c1.gra.k8s.ovh.net 8080:30012/TCP 9m10s app=gateway # export OPENFAAS_URL=xxxrt657xx.lb.c1.gra.k8s.ovh.net:8080 # echo -n $PASSWORD | ./faas-cli login -g $OPENFAAS_URL -u admin --password-stdin Calling the OpenFaaS server to validate the credentials... WARNING! Communication is not secure, please consider using HTTPS. Letsencrypt.org offers free SSL/TLS certificates. credentials saved for admin http://xxxrt657xx.lb.c1.gra.k8s.ovh.net:8080 # ./faas-cli version ___ _____ ____ / _ \ _ __ ___ _ __ | ___|_ _ __ _/ ___| | | | | '_ \ / _ \ '_ \| |_ / _` |/ _` \___ \ | |_| | |_) | __/ | | | _| (_| | (_| |___) | \___/| .__/ \___|_| |_|_| \__,_|\__,_|____/ |_| CLI: commit: f7c29ea19b5df9d7aa87e9c70aacf4d9315da2cd version: 0.12.4 Gateway uri: http://xxxrt657xx.lb.c1.gra.k8s.ovh.net:8080 version: 0.18.17 sha: 18f6c720b50db7da5f9c410f9fd3369ed7aff379 commit: Extract a caching function_query type Provider name: faas-netes orchestration: kubernetes version: 0.10.5 sha: 9be50543b372381a505e9e54a1356bb076c8f01f # ./faas-cli list Function Invocations Replicas
Deploying and invoking functions
You can easily deploy functions on your OpenFaaS platform using the CLI, with the command faas-cli up
Let’s use some sample functions from the OpenFaaS repository:
# ./faas-cli deploy -f https://raw.githubusercontent.com/openfaas/faas/master/stack.yml
Doing a faas-cli list
command now will show the deployed functions:
# ./faas-cli list
base64 0 1
echoit 0 1
hubstats 0 1
markdown 0 1
nodeinfo 0 1
wordcount 0 1
Let’s invoke one of those functions, for example wordcount
(a function that takes the syntax of the unix wc
command, giving us the number of lines, words and characters on the input data):
# echo 'I love when a plan comes together' | ./faas-cli invoke wordcount
1 7 34
Invoking a function without the CLI
You can use the faas-cli describe
command to get the public URL of your function, and then call it directly with your favorite HTTP library (or the good old curl
# ./faas-cli describe wordcount Name: wordcount Status: Ready Replicas: 1 Available replicas: 1 Invocations: 1 Image: functions/alpine:latest Function process: URL: http://xxxxx657xx.lb.c1.gra.k8s.ovh.net:8080/function/wordcount Async URL: http://xxxxx657xx.lb.c1.gra.k8s.ovh.net:8080/async-function/wordcount Labels: faas_function : wordcount Annotations: prometheus.io.scrape : false # curl -X POST --data-binary "I love when a plan comes together" "http://xxxxx657xx.lb.c1.gra.k8s.ovh.net:8080/function/wordcount" 0 7 33
Containers everywhere…
The main interest of a FaaS platform is to be able to deploy your own functions. In OpenFaaS you can write your these function on many languages, not only the usual suspects (JavaScript, Python, Go…). That’s is done because on OpenFaaS you can deploy basically any container as a function. As a side effect of it, you need to package your functions as containers in order to deploy them.
That also means that in order to create your own functions, you need to have Docker installed in your workstation, and you will need to push the images in a Docker registry, either the official one or a private one.
For this tutorial, we are choosing to deploy our image on the official Docker registry.
Writing our first function
For our first example, we are going to create a deploy a hello word function in JavaScript using NodeJS. Let’s begin by creating and scaffolding the function folder:
# mkdir hello-js-project
# cd hello-js-project
# ../faas-cli new hello-js --lang node
The CLI will download a JS function template from OpenFaaS repository, generate a function description file (hello-js.yml
in our case) and a folder for the function source code (hello-js
). For NodeJS, you will find a package.json
(for example to declare eventual dependencies to your function) and a handler.js
(the function main code) in this folder.
Edit hello-js.yml
to set the name of the image you’ll want to upload to docker registry:
hello-js.yml
version: 1.0
provider:
gateway: http://xxxxx657xx.lb.c1.gra.k8s.ovh.net:8080
functions:
hello-js:
lang: node
handler: ./hello-js
image: ovhplatform/openfaas-hello-js:latest
The function described in the handler.js
file is really simple. It exports a function with two parameters, a context
where you will receive the request data, and a callback
that you will call at the end of your function and where you will pass the response data.
"use strict"
module.exports = (context, callback) => {
callback(undefined, {status: "done"});
Let’s edit it to send back our hello world message:
"use strict"
callback(undefined, {message: 'Hello world'});
Now you can build the Docker image and push it to the public Docker registry:
# Build the image
# ../faas-cli build -f hello-js.yml
# Login at Docker Registry, needed to push the image
# docker login
# Push the image to the registry
# ../faas-cli push -f hello-js.yml
With the image in the registry, let’s deploy and invoke the function with the OpenFaaS CLI:
# Deploy the function
# ../faas-cli deploy -f hello-js.yml
# Invoke the function
# ../faas-cli invoke hello-js
Congratulations, you have written and deployed your first OpenFaaS function.
Using the OpenFaaS UI Portal
You can test the UI portal by pointing your browser to your OpenFaaS gateway URL (the one you have set on the $OPENFAAS_URL
variable), and when asked, using the user admin
and the password you have set on the $PASSWORD
variable.
In the UI Portal you will find the list of the deployed functions, and for each function you can find it description, invoke it and see the result.
Where do we go from here?
So now you have a working OpenFaaS platform on your OVHcloud Managed Kubernetes cluster.
To learn more about OpenFaaS, and how you can get a maximum profit from it, please refer to the official OpenFaaS documentation. You can also follow the OpenFaaS workshops to learn in a more practical way.
Comments
0 comments
