OVHcloud Managed Kubernetes service provides you Kubernetes clusters without the hassle of installing or operating them. This guide will explain how to deploy a simple Hello World application on a OVHcloud Managed Kubernetes cluster.
- an OVHcloud Managed Kubernetes cluster
- at least one node on the cluster
- a well-configured
kubectl
(see the configuring kubectl guide for details)
Step 1 - Deploy your first application
The following command will deploy a simple application (nginx image) using a Kubernetes Deployment and a Kubernetes Service.
Create a hello.yaml
file for our ovhplatform/hello
Docker image:
apiVersion: v1
kind: Service
metadata:
labels:
app: hello-world
spec:
type: LoadBalancer
ports:
- port: 80
targetPort: 80
protocol: TCP
selector:
app: hello-world
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: hello-world
spec:
replicas: 1
selector:
matchLabels:
app: hello-world
template:
metadata:
labels:
app: hello-world
spec:
containers:
- name: hello-world
image: ovhplatform/hello
ports:
- containerPort: 80
And apply the file:
# kubectl apply -f hello.yml
After applying the YAML file, a new hello-world
service and the corresponding hello-world-deployment
deployment are created:
service/hello-world created
deployment.apps/hello-world-deployment created
The application you have just deployed is a simple nginx server with a single static Hello World page. Basically, it just deploys the Docker image ovhplatform/hello
Step 2 - List the pods
You have just deployed a hello-world
service in a pod in your worker node. Let’s verify that everything is correct by listing the pods.
# kubectl -n=default get pods
You should see your newly created pod:
NAME READY STATUS RESTARTS AGE
hello-world-deployment-d98c6464b-7jqvg 1/1 Running 0 47s
Step 3 - List the deployments
You can also verify the deployment is active:
# kubectl -n=default get deploy
And you will see the hello-service-deployment
NAME DESIRED CURRENT UP-TO-DATE AVAILABLE AGE
hello-world-deployment 1 1 1 1 1m
Step 4 - List the services
And now you’re going to use kubectl
to see your service:
# kubectl -n=default get services
You should see your newly created service:
# kubectl get service hello-world
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
hello-world LoadBalancer 10.3.81.234 6d6regsa9pc.lb.c1.gra.k8s.ovh.net 80:31699/TCP 4m
If under EXTERNAL-IP
you get <pending>
, don’t worry, the provisioning of the LoadBalancer can take a minute or two, please try again in a few moments.
For each service you deploy with LoadBalancer type, you will get a new sub-domain XXXXXX.lb.c1.gra.k8s.ovh.net
to access the service. In my example that URL to access the service would be http://6d6regsa9pc.lb.c1.gra.k8s.ovh.net
Step 5 - Test your service
If you point your web browser to the service URL, the hello-world
service will answer you:
Step 6 - Clean up
At the end you can proceed to clean up by deleting the service and the deployment.
Let’s begin by deleting the service:
# kubectl delete service hello-world
If you list the services you will see that hello-world
doesn’t exist anymore:
service "hello-world" deleted
$ kubectl get services
No resources found.
Then, you can delete the deployment:
# kubectl delete deploy hello-world-deployment
And now if you list you deployment you will find no resources:
deployment.extensions "hello-world-deployment" deleted
$ kubectl get deployments
No resources found.
If now you list the pods:
# kubectl get pods
you will see that the pod created for hello-world
has been deleted too:
$ kubectl -n=default get pods
No resources found
To learn more about using your Kubernetes cluster the practical way, we invite you to look at our OVHcloud Managed Kubernetes doc site.
Comments
0 comments
