In this tutorial, we are using Kubernetes Volume Snapshots to back up and restore persistent volumes on an OVHcloud Managed Kubernetes cluster.
Volume Snapshots are a Kubernetes feature released in General Availability (GA) on Kubernetes 1.20.
They provide the ability to create a “snapshot” of a persistent volume. A snapshot represents a point-in-time copy of a volume. A snapshot can be used either to rehydrate a new volume (pre-populated with the snapshot data) or to restore an existing volume to a previous state (represented by the snapshot).
Before you begin
This tutorial assumes that you already have a working OVHcloud Managed Kubernetes cluster, and some basic knowledge of how to operate it. If you want to learn more about these topics, please check out the OVHcloud Managed Kubernetes Service Quickstart.
The tutorial also assumes that you’re familiar with Kubernetes Persistent Volumes. You also need to know how PVs are handled on the OVHcloud Managed Kubernetes service. Please refer to the Persistent Volumes on OVHcloud Managed Kubernetes guide.
Setup
In this guide, we are going to use a simple example: a small Nginx web server with a PersistentVolume
Create a file named nginx-example-with-pv.yml
with the following content:
apiVersion: v1
kind: Namespace
metadata:
labels:
app: nginx
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
namespace: nginx-example
labels:
app: nginx
spec:
storageClassName: csi-cinder-high-speed
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
strategy:
type: Recreate
replicas: 1
selector:
matchLabels:
app: nginx
template:
metadata:
labels:
app: nginx
spec:
volumes:
- name: nginx-logs
persistentVolumeClaim:
claimName: nginx-logs
containers:
- image: nginx:1.7.9
ports:
-containerPort: 80
volumeMounts:
- mountPath: "/var/log/nginx"
readOnly: false
apiVersion: v1
kind: Service
metadata:
labels:
app: nginx
spec:
ports:
- port: 80
targetPort: 80
selector:
app: nginx
type: LoadBalancer
Now apply it to the cluster:
kubectl apply -f nginx-example-with-pv.yml
Note: If you look at the deployment
part of this manifest, you will see that we have defined a .spec.strategy.type
. It specifies the strategy used to replace old pods with new ones, and we have set it to Recreate
, so that all existing pods are killed before new ones are created.
We do so because the Storage Class we are using, csi-cinder-high-speed
, only supports aReadWriteOnce
, so we can only have one pod writing on the Persistent Volume at any given time.
Wait until you get an external IP:
kubectl -n nginx-example get svc nginx-service -w
When you have a Load Balancer external IP, save it:
export LB_IP=$(kubectl -n nginx-example get svc nginx-service -o jsonpath='{.status.loadBalancer.ingress[0].ip}')
Make some calls to the URL to generate some access logs:
curl -I $LB_IP
Now, we need to connect to the pod to read the log file and verify that our logs are written.
First, get the name of the Nginx-running pod:
export POD_NAME=$(kubectl get po -n nginx-example -o name)
Then connect to it and view your access logs:
kubectl -n nginx-example exec$POD_NAME -c nginx -- cat /var/log/nginx/access.log
You should get a result like this:
$ kubectl apply -f nginx-example-with-pv.yml namespace/nginx-example created persistentvolumeclaim/nginx-logs created deployment.apps/nginx-deployment created service/nginx-service created $ kubectl -n nginx-example get svc nginx-service -w NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE nginx-service LoadBalancer 10.3.28.41 80:32675/TCP 4s nginx-service LoadBalancer 10.3.28.41 80:32675/TCP 91s nginx-service LoadBalancer 10.3.28.41 135.125.XX.XXX 80:32675/TCP 91s nginx-service LoadBalancer 10.3.28.41 135.125.XX.XXX 80:32675/TCP 95s $ export LB_IP=$(kubectl -n nginx-example get svc nginx-service -o jsonpath='{.status.loadBalancer.ingress[0].ip}') $ echo $LB_IP 135.125.XX.XXX $ curl -I $LB_IP HTTP/1.1 200 OK Server: nginx/1.7.9 Date: Mon, 26 Sep 2022 06:56:32 GMT Content-Type: text/html Content-Length: 612 Last-Modified: Tue, 23 Dec 2014 16:25:09 GMT Connection: keep-alive ETag: "54999765-264" Accept-Ranges: bytes $ curl -I $LB_IP HTTP/1.1 200 OK Server: nginx/1.7.9 Date: Mon, 26 Sep 2022 06:56:33 GMT Content-Type: text/html Content-Length: 612 Last-Modified: Tue, 23 Dec 2014 16:25:09 GMT Connection: keep-alive ETag: "54999765-264" Accept-Ranges: bytes $ export POD_NAME=$(kubectl get po -n nginx-example -o name) $ echo $POD_NAME pod/nginx-deployment-5bfc8c9f6f-zplsl $ kubectl -n nginx-example exec $POD_NAME -c nginx -- cat /var/log/nginx/access.log 10.2.0.0 - - [26/Sep/2022:06:56:32 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-" 141.94.164.46 - - [26/Sep/2022:06:56:33 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-"
Creating a Snapshot
Create a VolumeSnapshot
in an nginx-example-snapshot.yml
file with the following content:
apiVersion: snapshot.storage.k8s.io/v1
kind: VolumeSnapshot
metadata:
spec:
volumeSnapshotClassName: csi-cinder-snapclass-in-use-v1
source:
persistentVolumeClaimName: nginx-logs
Now apply it:
kubectl apply -f nginx-example-snapshot.yml
$ kubectl apply -f nginx-example-snapshot.yml volumesnapshot.snapshot.storage.k8s.io/nginx-snapshot created $ kubectl -n nginx-example get VolumeSnapshot NAME READYTOUSE SOURCEPVC SOURCESNAPSHOTCONTENT RESTORESIZE SNAPSHOTCLASS SNAPSHOTCONTENT CREATIONTIME AGE nginx-snapshot true nginx-logs 1Gi csi-cinder-snapclass-in-use-v1 snapcontent-131c751e-5cdb-4575-b0c0-538273c67d36 5m20s 5m20s
Simulate a disaster
Let’s simulate a disaster scenario, deleting the log files from the PVC
kubectl -n nginx-example exec$POD_NAME -c nginx -- rm /var/log/nginx/access.log
kubectl -n nginx-example exec$POD_NAME -c nginx -- ls -al /var/log/nginx/
$ kubectl -n nginx-example exec $POD_NAME -c nginx -- rm /var/log/nginx/access.log
kubectl -n nginx-example exec $POD_NAME -c nginx -- ls -al /var/log/nginx/
total 24
drwxr-xr-x 3 root root 4096 Sep 26 07:10 .
drwxr-xr-x 1 root root 4096 Jan 27 2015 ..
-rw-r--r-- 1 root root 0 Sep 26 06:54 error.log
drwx------ 2 root root 16384 Sep 26 06:54 lost+found
Restoring the Volume
To restore from a given snapshot, you need to delete the original PVC
and then recreate it from the snapshot.
Downscale the deployment to 0 replicas and delete the original PVC
kubectl -n nginx-example scale deployment/nginx-deployment --replicas=0
kubectl -n nginx-example delete pvc nginx-logs
Then, create an nginx-example-restore.yml
apiVersion: v1
metadata:
labels:
app: nginx
spec:
dataSource:
apiGroup: snapshot.storage.k8s.io
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
And apply it:
kubectl apply -f nginx-example-restore.yml
Verify that the PVC is restored:
kubectl -n nginx-example get pvc
The volume should have a status of Bound
. Now you can restore the deployment to its replica value of 1, and wait until the pod is Running
again:
kubectl -n nginx-example scale deployment/nginx-deployment --replicas=1
kubectl -n nginx-example get pods -w
Now you can verify that the access.log
file is back and that its content is still there:
echo $POD_NAME
$ kubectl -n nginx-example scale deployment/nginx-deployment --replicas=0 kubectl -n nginx-example delete pvc nginx-logs deployment.apps/nginx-deployment scaled persistentvolumeclaim "nginx-logs" deleted $ vi nginx-example-restore.yml $ kubectl apply -f nginx-example-restore.yml persistentvolumeclaim/nginx-logs created $ kubectl -n nginx-example get pvc NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE nginx-logs Bound ovh-managed-kubernetes-dmhe43-pvc-d5c65ae2-e9fd-48a9-8c29-d69cdd464f59 1Gi RWO csi-cinder-high-speed 7s $ kubectl -n nginx-example scale deployment/nginx-deployment --replicas=1 kubectl -n nginx-example get pods -w deployment.apps/nginx-deployment scaled NAME READY STATUS RESTARTS AGE nginx-deployment-5bfc8c9f6f-m627t 0/1 ContainerCreating 0 0s nginx-deployment-5bfc8c9f6f-m627t 0/1 ContainerCreating 0 7s nginx-deployment-5bfc8c9f6f-m627t 1/1 Running 0 10s $ export POD_NAME=$(kubectl get po -n nginx-example -o name) $ echo $POD_NAME pod/nginx-deployment-5bfc8c9f6f-m627t $ kubectl -n nginx-example exec $POD_NAME -c nginx -- ls -al /var/log/nginx/ total 28 drwxr-xr-x 3 root root 4096 Sep 26 06:54 . drwxr-xr-x 1 root root 4096 Jan 27 2015 .. -rw-r--r-- 1 root root 181 Sep 26 06:56 access.log -rw-r--r-- 1 root root 0 Sep 26 06:54 error.log drwx------ 2 root root 16384 Sep 26 06:54 lost+found $ kubectl -n nginx-example exec $POD_NAME -c nginx -- cat /var/log/nginx/access.log 10.2.0.0 - - [26/Sep/2022:06:56:32 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-" 141.94.164.46 - - [26/Sep/2022:06:56:33 +0000] "HEAD / HTTP/1.1" 200 0 "-" "curl/7.64.1" "-"
Cleanup
At the end, you can proceed to clean up by deleting everything. Delete the nginx-example
namespace:
kubectl delete namespace nginx-example
