Introduction
In this tutorial, you will learn how to deploy TrilioVault for Kubernetes (or TVK) to your OVHcloud Managed Kubernetes Cluster, create backups, and recover from a backup if something goes wrong.
You can back up your entire cluster by including multiple namespaces, or optionally choose a single namespace, label-based backups, Helm Release-based backups, or Operator-based backups.
Advantages of using Trilio:
- Take full (or incremental) backups of all your namespaces or selective applications, and restore them in case of data loss.
- Migrate from one cluster to another.
- Helm Release backups are supported.
- Backups of Operator-based application deployment are also supported.
- Run pre and post hooks for backup and restore operations.
- Web management console that allows you to inspect your backup/restore operations' states in detail (and many other features).
- Define retention policies for your backups.
- Application lifecycle (meaning TVK itself) can be managed via a dedicated TrilioVault Operator.
- Velero integration (Trilio supports monitoring Velero backups, restores, and backup/snapshot locations via its web management console).
How TrilioVault for Kubernetes Works
TVK follows a cloud native architecture, meaning that it has several components that, put together, form the Control Plane and Data Plane layers. Everything is managed via CRDs, making it fully Kubernetes-native. What is nice about Trilio is the clear separation of concerns and how effectively it handles backup and restore operations.
Each TrilioVault application consists of a bunch of “Controllers” and the associated CRDs. Every time a CRD is created or updated, the responsible controller is notified and performs cluster reconciliation. Then, the controller in charge spawns Kubernetes jobs that perform the real operation (like backup
, restore
, etc) in parallel.
Control Plane consists of:
- Target Controller: defines the storage backend (
S3
,NFS
, etc.) via specific CRDs - BackupPlan Controller: defines the components to back up, automated backups schedule, retention strategy, etc... via specific CRDs
- Restore Controller: defines restore operations via specific CRDs
Data Plane consists of:
- Datamover Pods - responsible for transferring data between persistent volumes and backup media (or
Target
). TrilioVault works with Persistent Volumes (PVs) using the CSI interface. For each PV that needs to be backed up, an ephemeral Datamover Pod is created. After each operation finishes, the associated pod is destroyed. - Metamover Pods - responsible for transferring Kubernetes API objects data to backup media (or
Target
). Metamover pods are ephemeral, just like the Datamover ones.
Understanding TrilioVault Application Scope
TrilioVault for Kubernetes works based on scope, meaning you can have a Namespaced or a Cluster type of installation.
A Namespaced installation allows you to back up
and restore
at the namespace level only. In other words, the backup is meant to protect a set of applications that are bound to a namespace that you own. This is how a “BackupPlan” and the corresponding Backup CRD works. You cannot mutate those CRDs in other namespaces - they must be created in the same namespace where the application to be backed up is located.
On the other hand, a Cluster type installation is not scoped or bound to any namespace or a set of applications. You define cluster type backups via the Cluster prefixed CRDs, like: ClusterBackupPlan
, ClusterBackup
, etc. Cluster type backups are a little bit more flexible in the sense that you are not tied to a specific namespace or set of applications to backup and restore. You can perform backup/restore operations for multiple namespaces and applications at once, including PVs (you can also backup etcd
databased content).
In order to make sure that the TVK application scope and rules are followed correctly, TrilioVault uses an Admission Controller. It intercepts and validates each CRD that you want to push for TVK, before it is actually created. In case the TVK application scope is not followed, the admission controller will reject CRD creation in the cluster.
Another important thing to consider is that a TVK License is application scope-specific. In other words, you need to generate one type of license for either a Namespaced or a Cluster type installation.
Namespaced vs Cluster TVK application scope - when to use one or the other?
Which one you should choose all depends on the use case. For example, a Namespaced scope is a more appropriate option when you don’t have access to the whole Kubernetes cluster - only to specific namespaces and applications.
In most cases, you want to protect only the applications tied to a specific namespace that you own.
On the other hand, a cluster scoped installation type works at the global level, meaning it can trigger backup/restore operations for any namespace or resource from a Kubernetes cluster (including PVs and the etcd
database).
To summarize:
- If you are a cluster administrator, then you will most likely want to perform cluster level operations via corresponding CRDs, like:
ClusterBackupPlan
,ClusterBackup
,ClusterRestore
, etc. - If you are a regular user, then you will usually perform namespaced-only operations (application centric) via corresponding CRDs, like:
BackupPlan
,Backup
,Restore
, etc.
The application interface is very similar or uniform when comparing the two types: Cluster vs non-Cluster prefixed CRDs. So, if you’re familiar with one type, it’s pretty straightforward to use the counterpart.
For more information, please refer to the TVK CRDs official documentation.
Back Up and Restore Workflow
Whenever you want to back up an application, you start by creating a BackupPlan
(orClusterBackupPlan
) CRD, followed by a Backup
(or ClusterBackup
) object. Trilio Backup Controller is notified of the change and performs backup object inspection and validation (i.e., whether it is cluster
backup, namespace
backup, etc.). Then, it spawns worker pods (Metamover, Datamover) responsible for moving the actual data (Kubernetes metadata, PVs data) to the backend storage (or Target
), such as OVHcloud Object Storage.
Similarly whenever you create a Restore object, the “Restore Controller” is notified to restore from a Backup object. Then, Trilio Restore Controller spawns worker nodes (Metamover, Datamover), responsible for moving backup data out of the OVHcloud Object Storage
(Kubernetes metadata, PVs data). Finally, the restore process is initiated from the backup object.
Trilio is ideal for the disaster recovery use case, as well as for “snapshotting” your application state prior to performing system operations on your cluster such as upgrades. For more details on this topic, please visit the Trilio Features and Trilio Use Case official page.
After finishing this tutorial, you should be able to:
- Configure OVHcloud Object Storage backend for Trilio to use.
Backup
andrestore
your applicationsBackup
andrestore
your entire OVHcloud Managed Kubernetes Cluster.- Create scheduled backups for your applications.
- Create retention policies for your backups.
Table of Contents
- Introduction
- Requirements
- Step 1 - Installing TrilioVault for Kubernetes
- Step 2 - Creating a TrilioVault Target to Store Backups
- Step 3 - Getting to Know the TVK Web Management Console
- Step 4 - Helm Release Backup and Restore Example
- Step 5 - Backup and Restore Whole Cluster Example
- Step 6 - Scheduled Backups
- Step 7 - Backups Retention Policy
- Conclusion
To complete this tutorial, you need the following:
- An OVHcloud S3 Object Storage Container/Bucket and an
S3
User with permission to access the Object Storage Container. - A Git client to clone the OVHcloud Docs repository.
- Helm for managing TrilioVault Operator releases and upgrades.
- Kubectl for Kubernetes interaction.
- krew for installation of preflight checks plugin.
Important Information: In order for TrilioVault to work correctly and to back up your PVCs, the OVHcloud Managed Kubernetes Cluster needs to be configured to support the Container Storage Interface (or CSI for short), and volumesnapshot
Custom Resource Definitions should be deployed.
kubectl get crd | grep volumesnapshot
The output should look similar to this:
volumesnapshotclasses.snapshot.storage.k8s.io 2022-01-20T07:58:05Z
volumesnapshotcontents.snapshot.storage.k8s.io 2022-01-20T07:58:05Z
volumesnapshots.snapshot.storage.k8s.io 2022-01-20T07:58:06Z
Also make sure that the CRD supports both, the v1beta1
and the v1
API versions. You can run the command below to check the API version:
kubectl get crd volumesnapshots.snapshot.storage.k8s.io -o yaml
At the end of the CRD yaml, you should obtain an output similar to below, showing storedVersions
as v1beta1
and v1
- lastTransitionTime: "2022-01-20T07:58:06Z"
message: approved in https://github.com/kubernetes-csi/external-snapshotter/pull/419
reason: ApprovedAnnotation
status: "True"
type: KubernetesAPIApprovalPolicyConformant
storedVersions:
- v1beta1
- v1
The user can then install the Hostpath CSI driver and create a storage class and a volume snapshot class. You can check the existing storage class using the following command:
kubectl get storageclass
The output should look similar to the output below (notice the provisioner is hostpath.csi.k8s.io if you have installed hostpath CSI driver):
NAME PROVISIONER RECLAIMPOLICY VOLUMEBINDINGMODE ALLOWVOLUMEEXPANSION AGE
csi-cinder-classic cinder.csi.openstack.org Delete Immediate true 3d
csi-cinder-high-speed cinder.csi.openstack.org Delete Immediate true 3d
csi-hostpath-sc (default) hostpath.csi.k8s.io Retain Immediate false 2d
Users should run a preflight check to make sure all the prerequisites for the TVK are fulfilled to proceed safely with installation. Follow the TVK Preflight Checks page to install and run preflight through the krew plugin.
In this step, you will learn how to deploy TrilioVault for Kubernetes for OVHcloud Managed Kubernetes Cluster, and manage TVK installations via Helm. Backup data will be stored in the OVHcloud Object Storage bucket created earlier in the Requirements section.
TrilioVault for Kubernetes consists of TVK Operator and TVM application.
The TrilioVault Operator (installable via Helm) which also installs the TrilioVault Manager CRD and creates a tvm
custom resource. TVK Operator handles the installation, post-configuration steps, and future upgrades of the Trilio application components.
Installing TrilioVault Operator and Manager Using Helm
Note: This tutorial is using the Cluster installation type for the TVK application (applicationScope
Helm value is set to “Cluster”). All examples from this tutorial rely on this type of installation to function properly.
Please follow the steps below to install TrilioVault via Helm:
First, clone the OVHcloud Docs Git repository and change the directory to your local copy:
git clone https://github.com/ovh/docs.git
cd docs/pages/platform/kubernetes-k8s/backup-and-restore-cluster-namespace-and-applications-with-trilio/
Next, add the TrilioVault Helm repository, and list the available charts:
helm repo add triliovault-operator http://charts.k8strilio.net/trilio-stable/k8s-triliovault-operator
helm repo update
helm search repo triliovault-operator
The output should look similar to the following:
NAME CHART VERSION APP VERSION DESCRIPTION
triliovault-operator/k8s-triliovault-operator 2.9.3 2.9.3 K8s-TrilioVault-Operator is an operator designe...
The chart of interest is triliovault-operator/k8s-triliovault-operator
, which will install TrilioVault for Kubernetes Operator on the cluster. You can run the helm install
command to install the Operator which will also install the TrilioVault Manager CRD. Install the TrilioVault for Kubernetes Operator using Helm
TVK allows the user to alter the values to be used by the TVK Operator installation using the --set
option. Check the detailed instructions in the One-click Installation page.
helm install triliovault-operator triliovault-operator/k8s-triliovault-operator --namespace tvk --create-namespace
Now, please check your TVK
deployment:
helm ls -n tvk
The output should look similar to the following (STATUS
column should display “deployed”):
NAME NAMESPACE REVISION UPDATED STATUS CHART APP VERSION
triliovault-manager-tvk tvk 1 2022-06-21 07:15:03.681891176 +0000 UTC deployed k8s-triliovault-2.9.3 2.9.3
triliovault-operator tvk 1 2022-06-21 07:13:18.731129339 +0000 UTC deployed k8s-triliovault-operator-2.9.3 2.9.3
Next, verify that the TrilioVault-Operator and TrilioVault-Manager application is up and running:
kubectl get deployments -n tvk
The output should look similar to the following (deployment pods must be in the Ready
state):
NAME READY UP-TO-DATE AVAILABLE AGE
k8s-triliovault-admission-webhook 1/1 1 1 45d
k8s-triliovault-control-plane 1/1 1 1 45d
k8s-triliovault-exporter 1/1 1 1 45d
k8s-triliovault-ingress-nginx-controller 1/1 1 1 13d
k8s-triliovault-web 1/1 1 1 45d
k8s-triliovault-web-backend 1/1 1 1 45d
triliovault-operator-k8s-triliovault-operator 1/1 1 1 45d
Now, please check your triliovaultmanagers
CRDs and the tvm
CR as well:
kubectl get crd | grep trilio
backupplans.triliovault.trilio.io 2022-06-21T07:39:38Z
backups.triliovault.trilio.io 2022-06-21T07:39:38Z
clusterbackupplans.triliovault.trilio.io 2022-06-21T07:39:39Z
clusterbackups.triliovault.trilio.io 2022-06-21T07:39:39Z
clusterrestores.triliovault.trilio.io 2022-06-21T07:39:39Z
hooks.triliovault.trilio.io 2022-06-21T07:39:39Z
licenses.triliovault.trilio.io 2022-06-21T07:39:39Z
policies.triliovault.trilio.io 2022-06-21T07:39:40Z
restores.triliovault.trilio.io 2022-06-21T07:39:40Z
targets.triliovault.trilio.io 2022-06-21T07:39:40Z
triliovaultmanagers.triliovault.trilio.io 2022-06-21T07:38:30Z
You can also check if the TVM Custom Resource is created.
kubectl get triliovaultmanagers -n tvk
The output looks similar to the following:
NAME TRILIOVAULT-VERSION SCOPE STATUS RESTORE-NAMESPACES
triliovault-manager 2.9.3 Cluster Deployed
If the output looks like the one above, you have installed TVK successfully. Next, you will learn how to check license type and validity, as well as how to renew a license.
TrilioVault Application Licensing
By default, when installing TVK via Helm, there is no Free Trial license generated. This tutorial will help you install the ‘Cluster’ scoped license, which is of the type ‘Basic’ for a cluster capacity of 500 CPUs and an expiration time of five years.
You can always go to the Trilio website and generate a new license for your cluster that suits your needs.
Installing TVK Application Licensing
Please run the below command to see what license is available for your cluster (it is managed via the License CRD):
curl -LO https://raw.githubusercontent.com/ovh/docs/develop/pages/platform/kubernetes-k8s/backup-and-restore-cluster-namespace-and-applications-with-trilio/manifests/tvk_install_license.yaml
kubectl apply -f tvk_install_license.yaml -n tvk
Run the below command to verify if the license is successfully created for OVHcloud users:
kubectl get license -n tvk
The output looks similar to the following (notice the STATUS
which should be “Active”, as well as the license type in the EDITION
column andEXPIRATION TIME
NAMESPACE NAME STATUS MESSAGE CURRENT NODE COUNT GRACE PERIOD END TIME EDITION CAPACITY EXPIRATION TIME MAX NODES
tvk trilio-license Active Cluster License Activated successfully. 3 Basic 500 2027-06-21T00:00:00Z 3
The license is managed via a special CRD
, namely the License
object. You can inspect it by running the following command:
kubectl describe license test-license-1 -n tvk
The output looks similar to the following (notice the Message
and Capacity
fields, as well as the Edition
Namespace: tvk
Labels: <none>
Annotations: generation: 1
triliovault.trilio.io/creator: kubernetes-admin
triliovault.trilio.io/instance-id: 46188ee1-8ce1-4c45-96fa-c262f2214ced
triliovault.trilio.io/updater:
[{"username":"system:serviceaccount:tvk:k8s-triliovault","lastUpdatedTimestamp":"2022-06-21T10:06:59.796280418Z"}]
API Version: triliovault.trilio.io/v1
Kind: License
Metadata:
Creation Timestamp: 2022-06-21T10:56:14Z
Current Node Count: 3
Max Nodes: 3
Message: Cluster License Activated successfully.
Properties:
Active: true
Capacity: 500
Company: OVHCloud License For Users
Creation Timestamp: 2022-06-21T00:00:00Z
Edition: Basic
Expiration Timestamp: 2027-06-21T00:00:00Z
Kube UID: 46188ee1-8ce1-4c45-96fa-c262f2214ced
License ID: TVAULT-4ddf3f72-d2ab-11ec-9a22-4b4849af53ee
Maintenance Expiry Timestamp: 2027-06-21T00:00:00Z
Number Of Users: -1
Purchase Timestamp: 2022-06-21T00:00:00Z
Scope: Cluster
The above output will also tell you when the license is going to expire in the Expiration Timestamp
field, and the Scope
(Cluster
based in this case). You can opt for a cluster-wide license type, or for a namespace based license. More details can be found on the Trilio Licensing documentation page.
Renewing TVK Application License
To renew the license, you will have to request a new one from the Trilio website, by navigating to the licensing page. After completing the form, you should receive the License YAML manifest, which can be applied to your cluster using kubectl
. The following commands assume that TVK is installed in the default tvk
namespace (please replace the <>
placeholders accordingly, where required):
kubectl apply -f <YOUR_LICENSE_FILE_NAME>.yaml -n tvk
You can check the new license status as you already learned via:
# List available TVK licenses first from the `tvk` namespace
# Get information about a specific license from the `tvk` namespace
kubectl describe license <YOUR_LICENSE_NAME_HERE> -n tvk
In the next step, you will learn how to define the storage backend for TrilioVault to store backups, called a target
TrilioVault needs to know first where to store your backups. TrilioVault refers to the storage backend by using the target term, and it is managed via a special CRD named Target
. The following target types are supported: S3
and NFS
. For OVHcloud, and the purpose of the tutorial, it makes sense to rely on the S3
storage type because it’s cheap and scalable. To benefit from an enhanced level of protection, you can create multiple target types (for both S3
and NFS
), so that your data is kept safe in multiple places, thus achieving backup redundancy.
OVHcloud provides two types of S3 compatible Object Storage solutions:
- To create a Target for the
OVHcloud Object Storage using S3 Swift API
, use this link. - To create a Target for the
OVHcloud Object Storage using High Performance
, use this link.
Create an S3 user in the tab next to Object Storage Container. Now, from Users and Roles
, assign the Administrator privileges to the S3 user.
Next, create an Access Key and Secret Key to access the S3 Object Storage Container using the Getting Started with the Swift S3 API tutorial.
Note: If you have created a container with High Performance, follow the Getting Started with S3 High Performance documentation.
Save the Access Key and Secret Key used in AWS CLI ~/.aws/credentails
file. It is required to create a target secret
later. Take a note of the S3 endpoint URL s3.endpoint_url
, and the region name region
provided in the AWS CLI ~/.aws/config
file. You will need this to create a Target
later.
To access S3 storage, each target needs to know the bucket credentials. A Kubernetes Secret must be created as well:
apiVersion: v1
kind: Secret
metadata:
namespace: tvk
type: Opaque
stringData:
accessKey: <YOUR_OVH_OBJECT_STORAGE_BUCKET_ACCESS_KEY_ID_HERE> # value must be base64 encoded
secretKey: <YOUR_OVH_OBJECT_STORAGE_BUCKET_SECRET_KEY_HERE> # value must be base64 encoded
Notice that the secret name is trilio-ovh-s3-target-secret
It’s referenced by the spec.objectStoreCredentials.credentialSecret
field of the Target CRD explained below. The secret
can be in the same namespace
where TrilioVault was installed (defaults to tvk
), or in another namespace of your choice. Just make sure that you reference the namespace correctly. On the other hand, please make sure to protect the namespace
where you store TrilioVault secrets viaRBAC
, for security reasons.
A typical Target definition looks like this:
apiVersion: triliovault.trilio.io/v1
kind: Target
metadata:
namespace: tvk
spec:
type: ObjectStore
vendor: Other # e.g. `AWS` for AWS S3 Storage and `Other` for OVHcloud Object Storage
enableBrowsing: true
objectStoreCredentials:
bucketName: <YOUR_OVH_OBJECT_STORAGE_BUCKET_NAME_HERE>
region: <YOUR_OVH_OBJECT_STORAGE_BUCKET_REGION_HERE> # e.g.: `bhs` region for OVHcloud Object Storage or `us-est-1` etc for AWS S3
url:"https://s3.<REGION_NAME_HERE>.cloud.ovh.net". # e.g.: `https://s3.bhs.cloud.ovh.net` for S3 Object Storage Container in `bhs` region
credentialSecret:
namespace: tvk
thresholdCapacity: 10Gi
Explanation for the above configuration:
spec.type
: Type of target for backup storage (S3 is an object store).spec.vendor
: Third party storage vendor hosting the target (for OVHcloud Object Storage, you need to use “Other” instead of “AWS”).spec.enableBrowsing
: Enable browsing for the target to browse through the backups stored on it.spec.objectStoreCredentials
: Defines required credentials (viacredentialSecret
) to access the S3 storage, as well as other parameters such as bucket region and name.spec.thresholdCapacity
: Maximum threshold capacity to store backup data.
Steps to create a Target
for TrilioVault:
- First, change directory where the
ovh/docs
Git repository was cloned on your local machine:
- Next, create the Kubernetes secret containing your target S3 bucket credentials (please replace the
placeholders accordingly):
kubectl create secret generic trilio-ovh-s3-target-secret \
--namespace=tvk \
--from-literal=accessKey="<YOUR_OVH_OBJECT_STORAGE_BUCKET_ACCESS_KEY_HERE>"\
--from-literal=secretKey="<YOUR_OVH_OBJECT_STORAGE_BUCKET_SECRET_KEY_HERE>"
- Then, open and inspect the
Target
manifest file provided in thedocs
repository, using an editor of your choice (preferably with YAML lint support). You can use VS Code for example:
cat manifests/triliovault-ovh-s3-target.yaml
- Now, replace the
placeholders accordingly to your OVHcloud Object Storage Trilio bucket, like:bucketName
,region
,url
, andcredentialSecret
. - Finally, save the manifest file and create the
Target
object usingkubectl
kubectl apply -f manifests/triliovault-ovh-s3-target.yaml
What happens next is TrilioVault will spawn a worker job named trilio-ovh-s3-target-validator
responsible for validating your S3 bucket (like availability, permissions, etc.). If the job finishes successfully, the bucket is considered to be healthy or available and the trilio-ovh-s3-target-validator
job resource is deleted afterwards. If something bad happens, the S3 target validator job is left up and running so that you can inspect the logs and find the possible issue.
Now, please go ahead and check if the Target
resource created earlier is healthy:
kubectl get target trilio-ovh-s3-target -n tvk
column value - should be “Available”, meaning it’s in a healthy state):
NAME TYPE THRESHOLD CAPACITY VENDOR STATUS BROWSING ENABLED
trilio-ovh-s3-target ObjectStore 10Gi Other Available Enabled
If the output looks like the above, then you have configured the S3 target object successfully.
Hint: In case the target object fails to become healthy, you can inspect the logs from the trilio-ovh-s3-target-validator
Pod to find the issue.
First, you need to find the target validator.
kubectl get pods -n tvk | grep trilio-ovh-s3-target-validator
The output looks similar to this:
trilio-ovh-s3-target-validator-tio99a-6lz4q 1/1 Running 0 104s
Now, fetch logs data.
kubectl logs pod/trilio-ovh-s3-target-validator-tio99a-6lz4q -n tvk
The output looks similar to this (notice the exception as an example):
INFO:root:2022-06-21 09:06:50.595166: waiting for mount operation to complete.
INFO:root:2022-06-21 09:06:52.595772: waiting for mount operation to complete.
ERROR:root:2022-06-21 09:06:54.598541: timeout exceeded, not able to mount within time.
ERROR:root:/triliodata is not a mountpoint. We can't proceed further.
Traceback (most recent call last):
File "/opt/tvk/datastore-attacher/mount_utility/mount_by_target_crd/mount_datastores.py", line 56, in main
utilities.mount_datastore(metadata, datastore.get(constants.DATASTORE_TYPE), base_path)
File "/opt/tvk/datastore-attacher/mount_utility/utilities.py", line 377, in mount_datastore
mount_s3_datastore(metadata_list, base_path)
File "/opt/tvk/datastore-attacher/mount_utility/utilities.py", line 306, in mount_s3_datastore
wait_until_mount(base_path)
File "/opt/tvk/datastore-attacher/mount_utility/utilities.py", line 328, in wait_until_mount
base_path))
Exception: /triliodata is not a mountpoint. We can't proceed further.
Next, you will discover the TVK web console which is a really nice and useful addition to help you manage backup and restore operations very easily, among many others.
Step 3 - Getting to Know theTVKWeb Management Console
While you can manage backup and restore operations from the CLI entirely via kubectl
and CRDs
, TVK
provides a Web Management Console to accomplish the same operations via the GUI. The management console simplifies common tasks via point and click operations, provides better visualization and inspection of TVK cluster objects, and creates disaster recovery plans (or DRPs
The Helm based installation covered in Step 1 - Installing TrilioVault for Kubernetes already took care of installing the required components for the web management console.
Getting Access to the TVK Web Management Console
To access the console and explore the features it offers, you can use either the Load Balancer, the Node Port, or you can port forward the ingress-nginx-controller service for TVK.
First, you need to identify the ingress-nginx-controller
service from the tvk
namespace:
kubectl get svc -n tvk
The output looks similar to the following (search for the k8s-triliovault-ingress-nginx-controller
line, and notice that it listens on port 80 in the PORT(S)
column):
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
k8s-triliovault-admission-webhook ClusterIP 10.3.241.124 <none> 443/TCP 45d
k8s-triliovault-ingress-nginx-controller NodePort 10.3.183.125 <none> 80:31879/TCP,443:31921/TCP 13d
k8s-triliovault-ingress-nginx-controller-admission ClusterIP 10.3.20.89 <none> 443/TCP 13d
k8s-triliovault-web ClusterIP 10.3.56.86 <none> 80/TCP 45d
k8s-triliovault-web-backend ClusterIP 10.3.236.30 <none> 80/TCP 45d
triliovault-operator-k8s-triliovault-operator-webhook-service ClusterIP 10.3.8.249 <none> 443/TCP 45d
If you are using the Load Balancer for the ingress-nginx-controller
, then the output would look like:
k8s-triliovault-ingress-nginx-controller LoadBalancer 10.3.183.125 51.222.45.171 80:31879/TCP,443:31921/TCP 13d
TVK is using an Nginx Ingress Controller to route traffic to the management web console services. Routing is host based, and the host name is ovh-k8s-tvk.demo.trilio.io
as defined in the Helm values file from the ovh/docs
# The host name to use when accessing the web console via the TVK ingress controller service
ingressConfig:
host: "ovh-k8s-tvk.demo.trilio.io"
Having the above information on hand, please go ahead and edit the/etc/hosts
file, and add this entry:
127.0.0.1 ovh-k8s-tvk.demo.trilio.io
Next, create the port forward for the TVK ingress controller service:
kubectl port-forward svc/k8s-triliovault-ingress-nginx-controller 8080:80 -n tvk
Finally, download the kubeconfig
file for your OVHcloud Managed Kubernetes Cluster present under the Service
tab as Kubeconfig file
. This step is required so that the web console can authenticate you using the kubeconfig file:
After following the above steps, you can access the console in your web browser by navigating to: http://ovh-k8s-tvk.demo.trilio.io. When asked for the kubeconfig
file, please select the one that you created in the last command from above.
Note: Please keep the generated kubeconfig
file safe because it contains sensitive data.
Exploring the TVK Web Console User Interface
The home page looks similar to:
Go ahead and explore each section from the left:
- Cluster Management: This shows the list including the primary cluster and other clusters having TVK instances, added to the primary OVHcloud cluster using the Multi-Cluster Management feature.
- Backup & Recovery: This is the main dashboard which gives you a general overview for the whole cluster (e.g., Discovered namespaces, Applications, Backup plans list, Targets, Hooks, Policies etc.)
- Namespaces:
- Applications:
- Backup plans:
- Targets:
- Scheduling Policy:
- Retention Policy:
- Namespaces:
- Monitoring: This has two options - TrilioVault Monitoring and Velero Monitoring - if the user has Velero configured on their OVHcloud cluster.
- TrilioVault Monitoring: It shows the backup and restore summary of the Kubernetes cluster.
- Velero Monitoring:
- Disaster Recovery: Allows you to manage and perform disaster recovery operations.
You can also see the S3 Target created earlier, by navigating to Backup & Recovery
> Targets
> Select the TVK Namespace from the dropdown on the top (in case of ovh/docs
the TVK Namespace is tvk
Going further, you can browse the target and list the available backups by clicking the Actions
button on the right. Then, select the Launch Browser
option from the pop-up menu (for this to work, the target must have the enableBrowsing
flag set to true
For more information and available features, please consult the TVK Web Management Console User Interface official documentation.
Next, you will learn how to perform backup and restore operations for specific use cases, like:
In this step, you will learn how to create a one-time backup for an entire Helm release from your OVHcloud Managed Kubernetes Cluster and restore it afterwards, making sure that all the resources related to the Helm release are re-created. The namespace in question is demo-backup-ns
. TVK has a neat feature that allows you to perform backups at a higher level than just Helm releases meaning complete namespaces, Label based application, and Operator based application. You will learn how to accomplish such a task in the steps to follow.
Next, you will perform the following tasks:
- Create the
demo-backup-ns
namespace and create amysql-qa
helm release for the MySQL Database - Perform a namespace backup, via Backup Plan and Backup CRDs.
- Delete the
mysql-qa
Helm release. - Restore the
mysql-qa
Helm release via Restore CRD. - Check the
mysql-qa
Helm release resources restoration.
Creating mysql-qa helm release
helm repo add stable https://charts.helm.sh/stable
helm repo update
helm install mysql-qa --set mysqlRootPassword=triliopass stable/mysql -n demo-backup-ns
To verify if the helm release is deployed correctly, run below command:
helm ls -n demo-backup-ns
mysql-qa demo-backup-ns 1 2022-06-21 08:23:01.849247691 +0000 UTC deployed mysql-1.6.9 5.7.30
Next, verify that mysql-qa
deployment is up and running:
kubectl get deployments -n demo-backup-ns
mysql-qa 1/1 1 1 2m5s
This shows that the mysql-qa helm release is ready to be backed up.
Creating mysql-qa Helm Release Backup
To perform backups for a single application at the namespace level (or Helm release), a Backup Plan followed by a Backup CRD is required. A Backup Plan allows you to:
- Specify a
target
where backups should be stored. - Define a set of resources to back up (e.g.: namespace or Helm releases).
- Set up encryption if you want to encrypt your backups on the target (this is a very nice feature for securing your backups' data).
- Define
schedules
for full or incremental type backups. - Define
retention
TrilioVault for Kubernetes has created a few sample scheduling and retention policies for users. Users can create the new policies or utilize the sample policies.
In other words, a Backup Plan is a definition of the “what”, “where”, “to”, and “how” of the backup process, but it doesn’t perform the actual backup. The Backup CRD is responsible for triggering the actual backup process, as dictated by the Backup Plan spec.
Typical Backup Plan CRD looks like the example below:
kind: BackupPlan
metadata:
namespace: demo-backup-ns
spec:
backupConfig:
target:
namespace: tvk
backupPlanComponents:
helmReleases:
- mysql-qa
spec.backupConfig.target.name
: Tells TVK what target name to use for storing backups.spec.backupConfig.target.namespace
: Tells TVK in which namespace the target was created.spec.backupComponents
: Defines a list of resources to back up (can be namespaces or Helm releases).
Typical Backup CRD looks like the example below:
kind: Backup
metadata:
spec:
type: Full
backupPlan:
spec.type
: Specifies the backup type (e.g.,Full
orIncremental
).spec.backupPlan
: Specifies theBackupPlan
which thisBackup
should use.
Steps to initiate the mysql-qa
Helm release one time backup:
- First, make sure that the
mysql-qa
is deployed in your cluster by following these steps. - Next, change the directory where the
docs
- Then, open and inspect the mysql-qa Helm release Backup Plan and Backup manifest files provided in the
pages/platform/kubernetes-k8s/backup-and-restore-cluster-namespace-and-applications-with-trilio/guide.en-us.md
cat manifests/mysql-qa-helm-release-backup-plan.yaml
cat manifests/mysql-qa-helm-release-backup.yaml
- Create the Backup Plan resource using
kubectl
kubectl apply -f manifests/mysql-qa-helm-release-backup-plan.yaml -n demo-backup-ns
Now, inspect the Backup Plan status (targeting the mysql-qa
Helm release) using kubectl
kubectl get backupplan mysql-qa-helm-release-backup-plan -n demo-backup-ns
The output should look similar to the following (notice the STATUS
column value which should be set to “Available”):
NAME TARGET ... STATUS
mysql-qa-helm-release-backup-plan trilio-ovh-s3-target ... Available
- Finally, create a Backup resource using
kubectl
kubectl apply -f manifests/mysql-qa-helm-release-backup.yaml -n demo-backup-ns
Now, inspect the Backup status (targeting the mysql-qa
kubect get backup mysql-qa-helm-release-full-backup -n demo-backup-ns
Next, check the Backup
object status using kubectl
kubectl get backup mysql-qa-helm-release-full-backup -n demo-backup-ns
column value which should be set to “InProgress”, as well as the BACKUP TYPE
set to “Full”):
NAME BACKUPPLAN BACKUP TYPE STATUS ...
mysql-qa-helm-release-full-backup mysql-qa-helm-release-backup-plan Full InProgress ...
After all the mysql-qa
Helm release components finish uploading to the S3 target, you should get the following results:
The output should look similar to the following (notice that the STATUS
changed to “Available”, and PERCENTAGE
is “100”)
NAME BACKUPPLAN BACKUP TYPE STATUS ... PERCENTAGE
mysql-qa-helm-release-full-backup mysql-qa-helm-release-backup-plan Full Available ... 100
If the output looks like this, you have successfully backed up the mysql-qa
Helm release. You can go ahead and see how TrilioVault stores Kubernetes metadata by listing the TrilioVault S3 Bucket contents.
Finally, you can check that the backup is available in the web console as well by navigating to Backup & Recovery -> Backup Plans
and selecting the demo-ns-backup
Namespace from the top drop-down menu (notice that it’s in the “Available” state, and the mysql-qa
Helm release was backed up in the “Component Details” sub-view)
Deleting mysql-qa Helm Release and Resources
Now, go ahead and simulate a disaster by intentionally deleting the mysql-qa
Helm release:
helm delete mysql-qa -n demo-backup-ns
Next, check that the namespace resources were deleted (listing should be empty):
kubectl get all -n demo-backup-ns
Restoring mysql-qa Helm Release Backup
Important notes:
- If restoring into the same namespace, ensure that the original application components have been removed. Especially ensure that the PVC of the application is deleted.
- If restoring to another cluster (migration scenario), ensure that TrilioVault for Kubernetes is running in the remote namespace/cluster as well. To restore into a new cluster (where the Backup CR does not exist),
source.type
must be set tolocation
. Please refer to the Custom Resource Definition Restore Section to view arestore
bylocation
example. - When you delete the
demo-backup-ns
namespace, the Load Balancer resource associated with the mysql-qa service will be deleted as well. So, when you restore themysq-qa
service, the Load Balancer will be recreated by OVHcloud. The issue is that you will get a New IP address for your Load Balancer, so you will need to adjust theA records
to route traffic into the domains hosted on the cluster.
To restore a specific Backup, you need to create a Restore CRD. A typical Restore CRD looks like this:
kind: Restore
metadata:
namespace: demo-restore-ns
spec:
source:
type: Backup
backup:
skipIfAlreadyExists: true
spec.source.type
: Specifies what backup type to restore from.spec.source.backup
: Contains a reference to the backup object to restore from.spec.skipIfAlreadyExists
: Specifies whether to skip restore of a resource if it already exists in the namespace restored.
Restore allows you to restore the last successful Backup for an application. It is used to restore a single namespace or Helm release protected by the Backup CRD. The Backup CRD is identified by its name: mysql-qa-helm-release-full-backup
First, inspect the Restore CRD example from the ovh/docs
Git repository:
cat manifests/mysql-qa-helm-release-restore.yaml
Then, create the Restore resource using kubectl
kubectl apply -f manifests/mysql-qa-helm-release-restore.yaml
Finally, inspect the Restore object status:
kubectl get restore mysql-qa-helm-release-restore -n demo-restore-ns
The output should look similar to the following (notice the STATUS column set toCompleted
, as well as the PERCENTAGE COMPLETED set to100
NAME STATUS DATA SIZE START TIME END TIME PERCENTAGE COMPLETED DURATION
mysql-qa-helm-release-restore Completed 0 2022-06-21T15:06:52Z 2022-06-21T15:07:35Z 100 43.524191306s
If the output looks like the one above, then the mysql-qa
Helm release restoration process has completed successfully.
Verifying Applications Integrity after Restoration
Check that all the demo-restore-ns
namespace resources are in place and running:
kubectl get all -n demo-restore-ns
The output looks similar to:
NAME READY STATUS RESTARTS AGE
pod/mysql-qa-665f6fb548-m8tnd 1/1 Running 0 91m
pod/mysql-qa-helm-release-full-backup-metamover-9w7s0y-x8867 0/1 Completed 0 9m2s
service/mysql-qa ClusterIP 10.3.227.118 <none> 3306/TCP 91m
deployment.apps/mysql-qa 1/1 1 1 91m
NAME DESIRED CURRENT READY AGE
replicaset.apps/mysql-qa-665f6fb548 1 1 1 91m
NAME COMPLETIONS DURATION AGE
job.batch/mysql-qa-helm-release-full-backup-metamover-9w7s0y 1/1 28s 9m2s
The next step deals with whole cluster backup and restore, thus covering a disaster recovery scenario.
In this step, you will simulate a disaster recovery scenario. The whole OVHcloud Managed Kubernetes Cluster will be deleted, and then the important applications restored from a previous backup.
- Create the multi-namespace backup, using a Cluster Backup Plan CRD that targets all important namespaces from your OVHcloud Managed Kubernetes Cluster.
- Delete the OVHcloud Managed Kubernetes Cluster, using the OVHcloud Control Panel.
- Create a new OVHcloud Managed Kubernetes Cluster, using the OVHcloud Control Panel.
- Re-install TVK and configure the OVHcloud Object Storage bucket as S3 target (you’re going to use the same S3 bucket, where your important backups are stored)
- Restore all the important applications by using the TVK web console.
- Check the OVHcloud Managed Kubernetes Cluster applications integrity.
Creating the OVHcloud Managed Kubernetes Cluster Backup using TVK Multi-Namespace backup feature
The main idea here is to perform an OVHcloud Managed Kubernetes Cluster backup by including all important namespaces, that hold your essential applications and configurations. Basically, we cannot name it a full cluster backup and restore, but rather a multi-namespace backup and restore operation. In practice, this is all that’s needed because everything is “namespaced” in Kubernetes. You will also learn how to perform a cluster restore operation via location from the target. The same flow applies when you need to perform cluster migration.
A typical Cluster Backup Plan manifest targeting multiple namespaces looks like this:
kind: ClusterBackupPlan
metadata:
namespace: default
spec:
backupConfig:
target:
namespace: default
backupComponents:
- namespace: default
- namespace: demo-backup-ns
- namespace: backend
- namespace: monitoring
Notice that kube-system
(or other OVHcloud Managed Kubernetes Cluster related namespaces) is not included in the list. Usually, this is not required unless there is a special case requiring some settings to be persisted at that level.
A typical Cluster Backup manifest targeting multiple namespaces looks like this:
kind: ClusterBackup
metadata:
namespace: default
spec:
type: Full
clusterBackupPlan:
namespace: default
Steps to initiate a backup for all of the important namespaces in your OVHcloud Managed Kubernetes Cluster:
- First, go to the directory where the
ovh/docs
cd docs
- Then, open and inspect the Cluster Backup Plan and Cluster Backup manifest files provided in the
docs
repository.
cat manifests/multi-ns-backup-plan.yaml
cat manifests/multi-ns-backup.yaml
- Create the Cluster Backup Plan resource using
kubectl
kubectl apply -f manifests/multi-ns-backup-plan.yaml
Now, inspect the Cluster Backup Plan status using kubectl
kubectl get clusterbackupplan multi-ns-backup-plan -n default
ovh-multi-ns-backup-plan trilio-ovh-s3-target ... Available
- Finally, create the Cluster Backup resource using
kubectl
kubectl apply -f manifests/multi-ns-cluster-backup.yaml
Next, check the Cluster Backup status using kubectl
kubectl get clusterbackup multi-ns-cluster-backup -n default
column value which should be set to “Available”, as well as the PERCENTAGE COMPLETE
set to “100”):
NAME BACKUPPLAN BACKUP TYPE STATUS ... COMPLETE
multi-ns-backup ovh-multi-ns-backup-plan Full Avilable ... 100
If the output looks like the one above, then all of your important application namespaces were backed up successfully.
Note: Please bear in mind that it may take a while for the full cluster backup to finish depending on how many namespaces and associated resources are involved in the process.
You can also open the web console main dashboard and inspect the multi-namespace backup (notice how all the important namespaces that were backed up are highlighted in a green color, in a honeycomb structure).
Re-creating the OVHcloud Managed Kubernetes Cluster and Restoring Applications
An important aspect to keep in mind is that whenever you destroy an OVHcloud Managed Kubernetes Cluster and then restore it, a new Load Balancer with a new external IP is created as well when TVK restores your ingress controller. So please make sure to update your A records
accordingly.
Now, delete the whole OVHcloud Managed Kubernetes Cluster using the OVHcloud Control Panel.
Next, re-create the cluster as described in Creating an OVHcloud Managed Kubernetes Cluster.
To perform the restore operation, you need to install the TVK application as described in Step 1 - Installing TrilioVault for Kubernetes. Please make sure to use the same Helm Chart version - this is important!
After the installation finishes successfully, configure the TVK target as described in Step 2 - Creating a TrilioVault Target to Store Backups, and point it to the same OVHcloud S3 bucket where your backup data is located. Also, please make sure that target browsing
is enabled.
Next, verify and activate a new license as described in the TrilioVault Application Licensing section.
To get access to the web console user interface, please consult the Getting Access to the TVK Web Management Console section.
Then, navigate to Resource Management > TVK Namespace > Targets
(in the case of ovh/docs
, the TVK Namespace is tvk
Going further, browse the target and list the available backups by clicking the Actions
flag set to “true”).
Now click on the multi-ns-backup-plan
item from the list, and then click and expand the multi-ns-backup
item from the right sub-window similar to:
To start the restore process, click the Restore
button. A progress window will be displayed similar to the one below:
After a while, if the progress window looks like the one below, then the multi-namespace
restore operation completed successfully.
Checking OVHcloud Managed Kubernetes Cluster Applications State
First, verify all of the cluster Kubernetes resources (you should have everything in place):
kubectl get all --all-namespaces
In the next step, you will learn how to perform scheduled (or automatic) backups for your OVHcloud Managed Kubernetes Cluster applications.
The ability to make backups automatically on a schedule is a really useful feature to have. It allows you to rewind back time and to restore the system to a previous working state if something goes wrong. This section provides an example for an automatic backup on a 15 minute schedule (the kube-system
namespace was picked).
By default, TrilioVault for Kubernetes creates the sample daily, weekly, and monthly scheduling policy after installation. Users can use the same scheduling policies if no changes are required. See the default values of the policies in the TVK UI scheduling policy:
First, you need to create a Policy CRD of the Schedule
type that defines the backup schedule in cron
format (same as Linux cron). Schedule polices can be used for either Backup Plan or Cluster Backup Plan CRDs. A typical schedule policy CRD looks like this (defines a 15 minute schedule):
kind: Policy
metadata:
namespace: default
spec:
type: Schedule
scheduleConfig:
schedule:
-"*/15 * * * *" # trigger every 15 minutes
Next, you can apply the schedule policy to a Cluster Backup Plan CRD, for example, as seen here:
metadata:
namespace: default
spec:
backupConfig:
target:
namespace: default
schedulePolicy:
fullBackupPolicy:
namespace: default
backupComponents:
Looking at the file above, you will notice that it’s a basic Cluster Backup Plan CRD, referencing the Policy CRD defined earlier via the spec.backupConfig.schedulePolicy
field. You can have separate policies created for full or incremental backups. Hence, the fullBackupPolicy
or incrementalBackupPolicy
can be specified in the spec.
Now, please go ahead and create the schedule Policy
, using the sample manifest provided by the ovh/docs
tutorial (make sure to change to the directory where the ovh/docs Git repository was cloned on your local machine):
kubectl apply -f manifests/triliovault-scheduling-policy-every-15min.yaml
Check that the policy resource was created:
kubectl get policies -n default
The output should look similar to this (notice the POLICY
type set to Schedule
NAMESPACE NAME POLICY DEFAULT
default scheduled-backup-every-15min Schedule false
Finally, create the backupplan
resource for the default
namespace scheduled backups:
Create the backup plan first for default namespace.
kubectl apply -f manifests/triliovault-multi-ns-backup-plan-every-15min.yaml
Check the scheduled backup plan status for default
kubectl get clusterbackupplan triliovault-multi-ns-backup-plan-every-15min.yaml -n default
The output looks similar to (notice the FULL BACKUP POLICY
value set to the previously created scheduled-backup-every-5min
policy resource, as well as the STATUS
which should be “Available”):
NAME TARGET ... FULL BACKUP POLICY STATUS
multi-ns-backup-plan-15min-schedule trilio-ovh-s3-target ... scheduled-backup-every-15min Available
Create a cluster backup resource using the scheduled policy for every 15 minutes.
Create and trigger the scheduled backup for the default namespace:
kubectl apply -f manifests/triliovault-multi-ns-backup-every-15min.yaml.yaml
Check the scheduled backup status for default
kubectl get clusterbackup multi-ns-backup-15min-schedule -n default
The output looks similar to (notice the BACKUPPLAN
value set to the previously created backup plan resource, as well as the STATUS
multi-ns-backup-15min-schedule multi-ns-backup-plan-15min-schedule Full Available ...
Now you can check that backups are performed on a regular interval (15 minutes) by querying the cluster backup resource and inspecting the START TIME
column (kubectl get clusterbackup -n default
). It should reflect the 15 minutes delta.
In the next step, you will learn how to set up a retention policy for your backups.
The retention policy allows you to define the number of backups to retain and the cadence to delete backups as per compliance requirements. The retention policy CRD provides a simple YAML specification to define the number of backups to retain in terms of days, weeks, months, years, latest, etc.
By default, TrilioVault for Kubernetes creates the sample retention policy sample-ret-policy
after installation. Users can use the same retention policy as no changes is required. See the default values of the policy in the TVK UI Retention policy:
Using Retention Policies
Retention polices can be used for either Backup Plan or Cluster Backup Plan CRDs. A typical Policy
manifest for the Retention
type looks like this:
kind: Policy
metadata:
spec:
type: Retention
retentionConfig:
latest: 2
weekly: 1
dayOfWeek: Wednesday
monthly: 1
dateOfMonth: 15
monthOfYear: March
yearly: 1
spec.type
: Defines policy type. Can beRetention
orSchedule
.spec.retentionConfig
: Describes the retention configuration such as what interval to use for backup retention and how many to make.spec.retentionConfig.latest
: Maximum number of the latest backups to be retained.spec.retentionConfig.weekly
: Maximum number of backups to be retained in a week.spec.retentionConfig.dayOfWeek
: Day of the week to maintain weekly backups.spec.retentionConfig.monthly
: Maximum number of backups to be retained in a month.spec.retentionConfig.dateOfMonth
: Date of the month to maintain monthly backups.spec.retentionConfig.monthOfYear
: Month of the backup to retain for yearly backups.spec.retentionConfig.yearly
: Maximum number of backups to be retained in a year.
The above retention policy translates to:
- On a
weekly
basis, keep one backup eachWednesday
. - On a
monthly
basis, keep one backup in the15th
day. - On a
yearly
basis, keep one backup everyMarch
. Overall
, I want to always have the2 most recent
backups available.
The basic flow for creating a retention policy resource goes the same way as with scheduled backups. You need a Backup Plan or a Cluster Backup Plan CRD defined to reference the retention policy, and then you need to have a Backup or Cluster Backup object to trigger the process.
A typical Cluster Backup Plan configuration with retention set looks like this:
metadata:
namespace: default
spec:
backupConfig:
target:
namespace: default
retentionPolicy:
namespace: default
backupComponents:
Once you apply the Cluster Backup Plan, you can check it using the following command:
kubect get clusterbackupplan -n default
The output should look similar to the example below:
NAME TARGET RETENTION POLICY ... STATUS
multi-ns-backup-plan-15min-schedule-retention trilio-ovh-s3-target sample-ret-policy ... Available
Notice that it uses a retentionPolicy
field to reference the policy in question. Of course, you can have a backup plan that has both types of policies set, so that it is able to perform scheduled backups as well as to deal with retention strategies.
Using Cleanup Policies
Having so many TVK resources (each one responsible for various operations such as scheduled backups, retention, etc.), something is likely to go wrong at some point in time. It means that some of the previously enumerated operations might fail due to various reasons such as inaccessible storage, network issues for NFS, etc.
So, what happens is that your OVHcloud Managed Kubernetes Cluster will get crowded with many Kubernetes objects in a failed state.
You need a way to garbage collect all those objects in the end and release associated resources to avoid trouble in the future. Meet the Cleanup Policy
CRD:
kind: Policy
metadata:
namespace: tvk
spec:
type: Cleanup
cleanupConfig:
backupDays: 5
The above cleanup policy must be defined in the TVK install namespace. Then, a cron job is created automatically for you that runs every 30 mins, and deletes failed backups based on the value specified for backupdays
within the spec field.
This is a very neat feature that TVK provides to help you deal with this kind of situation.
Conclusion
In this tutorial, you learned how to perform one time, as well as scheduled backups, and to restore everything. Having scheduled backups in place is very important as it allows you to revert to a previous snapshot in time if something goes wrong along the way. You walked through a disaster recovery scenario as well. Next, backup retention plays an important role as well, because storage is finite and sometimes it can get expensive if too many objects are implied.
All the basic tasks and operations explained in this tutorial are meant to give you a basic introduction and understanding of what TrilioVault for Kubernetes is capable of. You can learn more about TrilioVault for Kubernetes and other interesting (or useful) topics, by following the links below:
- TVK CRD API documentation
- How to Integrate Pre/Post Hooks for Backup Operations, with examples given for various databases
- Immutable Backups, which restrict backups on the target storage to be overwritten
- Helm Releases Backup, which shows examples for Helm releases backup strategies
- Backups Encryption, which explains how to encrypt and protect sensitive data on the target (storage)
- Disaster Recovery Plan
- Multi-Cluster Management
- Restore Transforms
- Velero Integration to Monitor Velero Backups
